Aeropress metal dis...
[Closed] Aeropress metal disc filter..?
Is it me or are they just harder to clean than the paper ones?
I find the paper filter ejects itself with the coffee grounds in a little puck, leaving the aeropress needing a mere quick rinse. However, the metal disc stays attached, needs rinsing etc...
Not "batterer" as I thought it may be.
Posted : 28/12/2017 11:02 am
Yes they are harder to clean. But it's just a rinse. I normally use paper at work and the metal ones at home
Posted : 28/12/2017 11:13 am
Harder to clean and much, much more expensive when you eject it into the bin by accident and forget about it. Since a pack of paper filters lasts about a year I don't see the point ...
Posted : 28/12/2017 12:23 pm
I just slide it off the top, it leaves all (well, ~95%) of the coffee in the aeropress so it can be pushed out into the bin, then give the metal disc a quick rinse.
Posted : 28/12/2017 12:37 pm
 scud
I just use the papers ones at home or work, the metal one lives in my camping gear box where i can usually just reuse it wiping it on wet grass.
Posted : 28/12/2017 12:53 pm
It does seem to be a bit of solution looking for a problem
Posted : 28/12/2017 5:40 pm
it's also just not as good as the paper filters, for me. unless i just have a shit one.
Posted : 28/12/2017 8:41 pm
Love my metal filters. Never have a problem cleaning them, a quick spray with WD40 before each brew, and they just slide off nice and clean post brew.
Posted : 28/12/2017 9:37 pm
I do mine in wax. Lasts a couple of months between treatments.
Posted : 28/12/2017 10:33 pm
