[Closed] Advice/help re burton snowboard bindings
Right be gentle... Old man requires advice from snowboarders on Stw.
In short I have a pair of cartel bindings circa 2005 .After blowing off the dust and digging out my pension book I have decided to use them in anger once more , however just noticed they are missing a flad lever..... Forward lean assist something or other .Anyway Burton can't help. So the question is do I need to replace it , if so any spares knocking around on line or in your drawer or is it functional without.
thanks.
What happens without the lever? Is the highback left loose and floppy?
If so then you probably need [i]something[/i], but you might not require adjustability if you already know how you like your forward lean. So a well-placed self-tapping screw or a bolt might do the job?
Failing that - buy some new bindings. Tech has moved on a fair bit in the past 10 years!
If you like a bit of forward lean then the lever is useful. If you're not bothered then ride without it, unless it one of the locking ones. Although I removed the locking bit off my missions as it meant you couldn't drop the high back when getting on a lift.
Have a look on eBay for an old set and buy them for spares, don't have to be cartels as a lot of the parts are generic.
Really?! Current Burton bindings look almost identical to mine of that approx vintage. Only real change is they're using less fixings and that's the 27.5/650B of snowboarding.
Def this
Though you'll probably find you can replace the bindings for not too much outlay.
They got rid of the clip thing that locks the highback into place because it doesn't really do much and I think also contributes to baseplates cracking and highbacks getting whacked by chairlifts. You can run a bit of forward lean even without the lever if you put a short screw in there instead (think they are 5mm or maybe 4mm) as long as you have the plastic spacer bit still. or just get some new HBs but the EST ones won't fit your baseplates.
I don't know about Cartels - but certainly a lot of other bindings seem to have got lighter, introduced different flex patterns, and added comfort things like dampening on the foot bed and adjustable toe ramps.
yeah bindings have got a hellavulotbetterer Union FTW
Have they got so good that I won't get sore feet after ten minutes?
(Still rocking Cartels from c2007-8 for the one week a year I actually get to go away).
Can you post a pic of what you're missing? I've got an old pair of Burton bindings of the same era, might be able to send you the missing bit.
I suffered with sore feet for years.
Two things helped enormously:
1) getting better boots/bindings that fit me well.
2) sorting out my technique (i.e. unlearning my 90's style swishy forward-facing riding and learning a more modern centered planted style)
I do sometimes still get sore feet after four or five days of riding, especially if it is icy or I am stuck on bashed hard pistes all the time, but it is much better than it used to be.
Union Flite Pro FTW! 🙂
Somebody tried to teach me this - I kept falling over. More perseverance required obviously 😀
Sore feet is generally technique and ill fitting boots/over tightening the binding straps.
As above, post a pic and I might have something that'll sort you out in my crate of knackered snowboard bindings.
Yeah stick with it. One other benefit is that a neutral duck-stance makes riding switch far easier.
I also found riding switch a good way to get used to the new stance as you have a bit less "muscle-memory" that way.
Well worth picking up a copy of the Neil McNab book if you are still as stuck in the past as I was:
[img]
[/img]
http://www.amazon.co.uk/dp/1405315741
doesnt everyone get sore feet for the first ten minutes, then you warm up...
It takes me a good 3-4 weeks into the season for my feet and legs to feel strong.
I have no idea how I used to cope with doing a 1-week holiday.
7EEDC1B7-A570-4CB9-BFBA-3E601C434A97
Thanks to all who have contributed .... Trying to load photo re missing lever and having a mare !
Raify and stevomcd , any chance you can email me (in profile) so I can send you pics direct ? .... Not signed up to an image hosting site so can't post on forum .thanks
Yeah stick with it. One other benefit is that a neutral duck-stance makes riding switch far easier.I also found riding switch a good way to get used to the new stance as you have a bit less "muscle-memory" that way.
Found the book/DVDs really hard to understand for some reason. I'm lucky enough to have been on one of the early McNab courses and it made a lot more sense how he used to teach it in person. Whatever though I'm sure once you get used to staying centred and "steering" with the front foot it'll be night and day better than the "French way". (I'm sure the French don't teach that way these days.
Good luck
The only thing I struggled with was that the book is all written as a goofy rider (probably not an issue for the OP!).
I made myself a little cut-out snowboard with the equivalent A-B-C-D for a regular rider, so I could easily refer to it when reading the book. That helped me visualise it a lot better.
goofyfoot: I'll post something up tonight.
[url= http://postimg.org/image/gsfea5yw7/66975f44/ ]right binding without lever[/url][url= http://postimg.org/image/qsnrgbq8b/b2133773/ ]left with lever[/url]
fingers crossed …link should show pics and hopefully explain the issue
Can you still adjust the height of that white bit, possibly by loosening the black screw/bolt?
If so then what you have looks like it will work fine to me.
That's exactly what's on my old bindings. I'll dig them out of the loft tonight and check they're still OK to use.
Did you call Burton Rider Service on 00800 287 866 13? They're usually pretty good with spares.
cheers Raify, I f you're happy to post email me and I 'll happily throw you a few quid.
beargrease: Yep, in fairness were quick to respond but don't carry spares for anything that old I was told .
I can't figure out how to private message you Goofyfoot. Send your post address to nathanjamesrobinson (AT) yahoo DOT co DOT uk
I'll stick them in a jiffy bag.
raify: email sent .thanks
