Advice needed on fi...
[Closed] Advice needed on finding Socket Set for an Inpact Driver
I’m looking for an 1/4 hex drive Socket Set for my Impact Driver. I am struggling to find any reputable makes producing a combined unit with a fullish range of sizes (metric), but lots of hex to 1/4, 3/8 and 1/2 adapters. Is this the best option? I also want something that I can leave in the impact driver box rather than using in conjunction with the 3/8 socket set I have. Any suggestions please?
Posted : 03/03/2019 10:05 am
I think the lack of availability should be telling you something...
Like putting a significant amount of torque through 1/4" and the associated socket sizes is a bit silly.
What do you need it for? Are you even weaker than me?!
If you're struggling to undo something like a 12mm hex head due to corrosion, then all an impact driver will do is shear it more efficiently.
Unless I'm missing something/I've misunderstood your question?
Posted : 03/03/2019 10:25 am
I have this set from Screwfix, but as mentioned above and on the page, you don't want to be putting much torque through them.
https://www.screwfix.com/p/erbauer-impact-driver-socket-set-3-pack/6297d
The description is kind of contradictory. Says they're impact driver bits, then that you shouldn't use them in an impact driver...
Posted : 03/03/2019 10:40 am
I just bought a cheap set from the local hardware store. Look pretty similar in style to that erbauer set above. No need for anything fancy in 1/4 as there won't be much torque. I also use normal 1/4 square drive sockets with a hex adapter. Never broken one.
Mine look like this (widely available with different brands) and were very cheap but are perfectly adequate strength wise
Posted : 03/03/2019 11:38 am
Nut runner is the name your looking for
Those little hex impact drivers are good for running nuts up but they have no breakout torque when it comes to a hex.
If you think your going to be removing anything that's pretty well snugged up you'll be surprised that it won't do it.
Posted : 03/03/2019 12:59 pm
It’s more for tightening than removing, reason for the impact driver is simply that’s what I use and like the quickness of hex shanks. I don’t see that there would be much of an issue using an impact driver given they make specific pozi and torx bits
Posted : 03/03/2019 1:23 pm
