Adhesive experts
[Closed] Adhesive experts
What epoxy will glue carbon fibres to metal (specificaly titanium and steel)?
๐Ÿ˜€
Posted : 04/05/2011 10:47 am
You two should just get a room together.
Posted : 04/05/2011 10:49 am
actually two rooms, some distance apart, but with no means of communication would be best.
Posted : 04/05/2011 10:50 am
What applications/load directions etc? Almost any epoxy will bond to a keyed metal surface, just not with the sort of strength you'd want in a safety critical application unless you're a qualified composites engineer (we do have one on here IIRC). Incidentally epoxy is pretty much the sole matrix material for carbon fibre bike parts and in that case it's usually bonded to things like the alloy forms for the headset, BB, dropouts etc. The joints need to be thought out carefully though, as "peel" is a weak point, my old crank arms delam'd from their alloy square taper bits due to the rotational forces peeling the bonding away from the alloy surface.
Posted : 04/05/2011 11:01 am
If you're gonna sniff it don't get the tube stuck to your nose.
Posted : 04/05/2011 11:02 am
Ta CK - it may be that the peeling effect has done for my design, I'll have a look and think.
Posted : 04/05/2011 11:14 am
try dp420 its a good un..... spabond from Gurit are another similar product 365 springs to mind however the metallics may need to be treated to get the best from them either mechanically blasted then degreased or chemically by applying a substrate(I spent many years designing glued things and the glue isn't the only consideration here)I have no idea what your joint design is like or the forces but on the whole either epoxy will join them
Posted : 04/05/2011 12:39 pm
