Aaargh! Van key rem...
[Closed] Aaargh! Van key remote buggered.
Got a Vivaro van and the remote had always required a little bit of pushing to unlock and switch the alarm off but was never a problem. Until now... Come to unlock it and it won't have it. Thought it was the battery so got a new one. Nope.
When I split the casing to put the battery in and have a look at the actual switches on the pcb the 'off' one doesn't click. The 'on' does have a click and still work. An LED lights up as it does.
This is my only key for the van. Anybody know if it possible to get a new one coded to it with it in its present state? Any suggestions/advice very welcome.
Ta.
Posted : 12/03/2015 3:20 pm
Isn't there a manual over-ride, to at least get you in?
(On my car it's a mechanical lock on the underside of the passenger side door handle)
Posted : 12/03/2015 3:26 pm
Not that I know of. If I open it manually the alarm goes off.
Posted : 12/03/2015 3:31 pm
There are services that offer to re-body your key for you & cna also solder on replacement switches if the originals are knackered like yours appear to be. This is referrign to Mercedes services I've seen but I'm sure that most/all marques are catered for. Have a Google?
If you're happy splitting down the key yourself then potentially this is something you could have a go at, depending on soldering knowledge and part availability?
Posted : 12/03/2015 4:01 pm
Master key should open the car with alarm not going off . At least it does on my car. No master key - hmm
Posted : 12/03/2015 4:02 pm
Its probably a buggered micro switch jobby. I've just replaced mine which did same (vivaro)
Cheap enough on eBay but need to be soldered if you've got the skills/feeling brave.
Edit, too slow/what he said ^^
Posted : 12/03/2015 4:04 pm
Don't know your van but with mine, getting the key into the ignition stops the alarm going off. With some others, you need to actually set the ignition
Posted : 12/03/2015 4:06 pm
Simon, I've sent you a text.
Posted : 12/03/2015 4:08 pm
On a car i had you turned the key the opposite way to opening the door first for a few seconds which disabled the alarm before opening the door
Posted : 12/03/2015 5:30 pm
 ps44
I got mine fixed by these guys: http://www.automobilelocksmith.co.uk/
Good as new
Posted : 12/03/2015 5:45 pm
Thanks everybody. Got a plan of action now. Cheers.
Posted : 12/03/2015 6:15 pm
