50mm thick concrete...
[Closed] 50mm thick concrete slabs in low numbers?
10 Users
I need 15 (assuming 45cm x 45cm) for a base for a metal shed.
£325 for a pack of 20 at Wickes is a bit more than I had in mind, and I don't want to drive to Sheffield or Hull for the ones that come up on ebay or gumtree.
Any ideas for a source in or near north London?
(I don't fancy lifting them off the pavement either, before you ask!)
Posted : 23/10/2012 10:35 am
Pour a slab?
Posted : 23/10/2012 10:37 am
Reclamation or salvage yard should have some
You could try local driveway companies too, they might let you have them cheap instead of putting them in the skip
Posted : 23/10/2012 10:58 am
That's the idea I started with, but then I'm into shuttering and mixer hire and a bit more of an undertaking. I'd rather just put down a sand or dry mix base and whack a few slabs on top.
cheer carlos, good ideas.
Posted : 23/10/2012 10:59 am
cheer[b]s[/b] carlos!
Posted : 23/10/2012 11:02 am
325 for 20 paving flags!!!! Seen coming mate. Go to travis perkins or Jewsons... You should be able to get them down to £4.50 per flag including the vat top side.
Sure you didnt get quoted on a decorative flag ? A plain concrete one is all you need.
Posted : 23/10/2012 11:07 am
Another suggestion if the reclaim yard or driveway companies is asking some local Garden Landscapers - they may have some left overs from a job they want rid of - or even may be lifting some which can be re-used.
Alternative to Gumtree is Freegle aka Freecycle. Worth a look. Used to be a Yahoo Group but now much more stand alone.
Posted : 23/10/2012 11:10 am
+1 Lowey - Something seriously wrong if you have to fork out more that £100 (including delivery) - I used local builders merchants
Posted : 23/10/2012 11:35 am
Got about 5 or 6 in the back yard if you're ever close to South Wales. FOC.
Posted : 23/10/2012 11:37 am
+1 for freecycle - I wanted some (12 IIRC) for the base of a shed, put up a request, had a response within half an hour, they were in the boot of my car the same day. I did have to carry them up a decent length garden, but they were free and less than 5 miles drive away, so I didn't complain to vociferously!
Cheers, Rich
Posted : 23/10/2012 11:53 am
I've got 20+ you can have for free if you don't mind collecting from Bath.
Posted : 23/10/2012 12:11 pm
Just found out there's a builders merchants literally around the corner who aelljust what I need in singles, for an OK price. Shed ordere, delivery in 5 weeks 🙁
Plenty of time to get the base sorted, though!
Posted : 31/10/2012 2:56 pm
Could also cast your own paving slabs - reusable slab moulds can be had for about £10 each, then buy bags of premixed concrete from a DIY store.
Posted : 31/10/2012 3:33 pm
