In a recommend what you own style thread, we're looking for a cool box that'll keep things cool for 5 days while camping.
Won't have any electric supply so fridges are off the menu.
Are Yeti the best or are they all about the gram? What works what doesn't.
Not sure, but if you really want to keep things cool for 5 days, I'd get 2 cool boxes. You could spend a few hundred quid on some mega Yeti thing, but if you're regularly opening the great big hole in the top, replacing cold air with warm air, taking stuff out and putting it back in again slightly warmer, it's not still going to be chilly in 5 days.
Have a first 3 days cool box, and another for the last 2 days which you don't open at all until you need it.
Also, when go away for just a weekend, you not wedded to the massive chest freezer thing because that's what you poured your money into, you can just take one of the two smaller ones .
Pretty sure nothing is going to work for 5 days unless you're adding ice/cool packs from the freezer.
Won’t have any electric supply so fridges are off the menu
Mine runs off gas as well.
plus what tom said, really. Are you staying at a site where you can rotate ice packs in the site freezer?
If not, are you by a river? You keep space for a litre bottle of water and refill with cold river water, if it's clean enough. Or rotate cold river rocks. Or build a cleit.
It's for festival use
I would just buy a big cheap one and fill the bottom with PET bottles full of ice, with ice cubes to fill the gaps. Put your food on top. Basically, the larger the mass of ice you have, the longer it will stay cold.
They make 5 day coolers, we have one. It's good, but no way is it 5 days. I also don't think not opening the lid is going to make a lot of difference. The amount of heat in a few litres of warm air is tiny compared to that stored in the cold stuff inside and compared to that which will leak in over 5 days.
I would be looking at an electric coolbox and a solar panel. Sure, it'll only work during the day, but it's much cooler at night so you could probably survive on the stored coolness. The 24l coolbox only draws 40W, so if you were to get say a 150W solar panel you would easily be able to run that even if it's not sunny, I reckon.
We used the in-car 12l one as a camping fridge on one trip, although not solar. It worked well, but the daytime temps were only low 20s. Overnight it froze our milk. If your day temps are high 20s, it will only be 10C ish in the cooler which isn't enough to keep milk for 5 days I think.
+1 Coleman Xtreme. The bigger the better as you can fit more ice packs in them.
I've got the previous model of this one - https://www.colemanuk.co.uk/cool-boxes/hard-cool-boxes/28qt-xtreme-cooler-box/SAP_2000037209.html - and if kept in the shade in moderate British weather the ice packs take a couple of days to melt.
5 days? You need the biggest one which are around 200 quid - https://www.colemanuk.co.uk/cool-boxes/hard-cool-boxes/100qt-xtreme-wheeled-cooler-box/SAP_2000037216.html - and will need to top the ice up every couple of days.
I used on of these round Oz in high temps, relying on blocks of ice - pretty effective. Ice cubes are crap.
https://24tackle.com/igloo-cooler-sportsman-52-green-49liters-p-2367.html
I bought one back in UK and have used it for weekend festivals. You wont have ice cold beers by the last day, but the marg/cheese will be solid. It's old and seems discontinued but I'd hope that the newer ones are just as good.
The less you open it the better, so plan what you want to get out, don't let the kids keep opening it (the cold air will sink so it's not as bad you think). Also important to keep it out of the sun and not in a hot car. If really trying, cover it in a wet towel...
If taking meals, freeze everything you can so it slowly defrosts, also frozen 2l milk containers of water make great ice blocks and stop the water going everywhere. frozen UHT milk also makes good ice blocks.
Sounds a bit daft but pre chill the esky before you load it (with frozen stuff you arent taking, that can go back in your freezer)
A second drinks esky can work for a day or two, and then switch to red wine...
or splash out on a gas/elec powered fancy fridge/freezer (The cheap powered coolboxes can't cope even on a warm UK day)
Ps big eskys can be a pain to move when full, but so act as a decent seat
I reckon you could keep milk fresh for 5 days with judicious use of a coleman Xtreme.
It’s for festival use
Whatever the local bar is, get ice in everything and even chance your arm for a pint glass full of it. Then run that back to the coolbox to replenish.
Found out some time ago they aren’t actually cool boxes as such, they can only reduce the temp inside by 15c so on a hot day in your car they don’t stand a chance
They are cool boxes insofar as they are an insulated box, built the same as any other coolbox, only with an additional active cooler inside. So if you put cold stuff inside as you would a normal coolbox, you just have an an extra cooling effect. The difference being that it's keeping it 15 (or 18) degrees below ambient on day 5, the same as day 1. These things aren't full on fridges but nor are they gimmicks.
We've an IceyTek and it'll do a good job for a few days, after that needs ice top-ups. Trick is pre-cooling it for a day or two before you go.
Our large electric Halfords one does about 3 days with ice blocks and no power. Freeze quite a bit of the food (eg spaghetti bol or curry).
We'll be off grid again for 3 to 4 days in July.
Top tip. Bags of frozen peas stay frozen longer than bags of ice or ice packs
TBH it sounds like you are asking too much, and in point of fact its just not possible to have a coolbox remain cold for 5 days.
Can I ask though. What is so important that you need to keep it cold for that long ? Diabetic medicine i can understand. But if it is beer, butter or milk, then look to another source or just do without.
Worx do a battery powered coolbox
I have a Dometic Combicool which runs off 240AC, 12V DC and most relevantly gas bottles. Did us fine for a week camping in France with no elec, just a 4.5kg butane using the gas for cooking too.
+another for Coleman extreme. Mine will do 3 days easy, especially if I really cool it down before use (stick some bottles of frozen water in there overnight before I pack it next day). Don't keep opening it is the main thing, nothing will stay cool for long if you're opening it all the time.
You’ll get 3 days from a yeti in my experience. Especially if you pre-cool and keep out of direct sunlight
Coleman extreme user too.
Freeze as much as you can eg. Bacon, sausages, spaghetti bolognaise etc and milk. Freezing beer / soft drinks cans is an art which deserves a thread of its own. Sometimes you win and sometimes you don't 🤫.
A big esky is best. Second best will be Coleman's etc ... as I suspect eskys are not that available in the UK.
Yeah naw mate
https://queenslandcamping.com.au/the-best-esky-australia/
Yeti ones are superb. We travel with frozen dog food when we go on holiday and it stays frozen for a good 48 hours in one. Pricey but will last a lifetime.
Get a 12/240/gas unit. 12v in car, 240v at Christmas for the drinks, gas cartridge whilst at festival (they need to be vented to don't run inside a tent, especially if it's got a sewn in groundsheet) Best hidden behind the hedge under the shade of a hedgehow or something .
Don't get a peltier type cool boxes, they are only useful whilst driving, once parked they will suck a car battery dry in just a few hours and you will be trying to bump start your car the following morning.
I doubt that very much. Water is known for having a very high specific heat capacity. I can't find the exact value for peas, but carrots are only 3.86 (kJ kg − 1 °C − 1 whereas water is 4.2.
Then you've got the Latent heat of the water,/ ice to take into account as well, which you don't get with the peas as they don't melt!
we've a coleman exreme, they generally need a bag of ice every 2 days but keep everything nice and cold in france in the middle of summer (30C peaks) - beers etc are as you'd expect just out of a decent fridge. You could probably run one for 5 days without topping up but the contents would have to be 90% ice to start with. If you've access to a supermarket or at a decent campsite (most french ones have a freezer for freezing ice packs) you should be grand
ours is a 66l - its massive on the outside, so check the size before you order something similar as they take a lot of room in the car. Ours just fits on the middle seat wedged between that and the front seats, in a fairly large car. Stops the kids fighting in the back as they can't see each other
Our big Coleman Xtreme is an amazing thing but the smaller version was disappointing, so much so that they refunded us.
Even with the big one we top it up with a bag of ice occasionally. If you start off with plenty of frozen stuff and keep the sun off it, I reckon youve half a chance.
Yeti - cult following in the US (especially in the huntin', fishin', overlandin' communities in the US where you're outside and it's hot AF), good products, with really good customer service.
I have a few bits of Yeti kit in daily use (bottles, tumblers, etc) and it's been awesome. One minor issues I (suspect it was a clumsy teenagers fault as much as anything) was sorted out megafast and free.
I don't have a cooler - I have a fridge in my van that will run off 12V leisure battery and solar for a week in 25C weather without hookup - but if I needed one it would be a Yeti or Icey-Tek which the offshore fishermen seem to rate.
I go to lidl and grab a load of the 2 litre orange and apple juice cartoons then freeze those solid to use as the 'fuel' for keeping everything else cold in ours.
As others have said freeze everything that's going in there and fill it as much as you can.
Never tried the 2 boxes for days 1-3 and 4-5 idea but I reckon that sounds like it could work
Not sure if you can get them in the uk but Makita make a battery powered fridge cooler
