2 meter bath option...
[Closed] 2 meter bath options
I am about to "hit the button" on the Conoduo as I want a bath at least 2meter long and up to 110cm wide and the Cono is 2X1m
are there any others I should consider?
Posted : 22/11/2018 6:05 pm
I hope you have a really good hot water system!  We have a 180x70 and it takes an age to fill.  Its also big enough for two.  That sounds more like a small swimming pool!
Posted : 22/11/2018 6:10 pm
not a problem in the summer I can fill a 10 foot 3000 litre pool at 35deg C from my system set to 60 deg c
I have a 185X90 upstairs which isnt big enough for me so I am going to do a 2 meter one downstairs as I have a concrete floor.
Ideally it would be 2500 X 1100, but I cant find anything that size available!
Posted : 22/11/2018 7:19 pm
This one maybe:  https://www.bette.de/en/produkte/produktfinder/badewannen/detail?p=Free
Posted : 22/11/2018 7:53 pm
That’s too big. We were going to go 2m * 90cm until we tried it. Too long to sit comfy in.
Posted : 22/11/2018 8:07 pm
^ not if you’re full sized! I’ve got 1800 in at 6’2 was biggest I could squeeze in to the space and my knees still stick up! Although having added about 50% more volume to the tub and new taps taking most of the flow away I’ve had one bath since fitting it....
Posted : 22/11/2018 8:12 pm
# Nick I have the same problem mate, not to mention XL bikes getting smaller.
the Bette is a good call but it uses 2mm steel and the Conoduo uses 3.5mm so even tough its a bit more expensive - it is worth it.
Posted : 23/11/2018 10:06 am
