Trying to set up 1x10 with a Hope Retainer, T-Rex ring and XT cassette. Everything is fitted and gears shift ok but it sounds and feels rough in every gear. Also the pedals keep turning when freewheeling especially when in the smaller sprockets - was fine when running 3x10.
Chainline is straight when in the 5th smallest sprocket and pretty sure the chain isn't too tight.
Any advice on how to sort this would be great unless it's just how 1x10 is.
the fact that the pedals turn when freewheeling sounds like it might be a freehub issue.
Are the jockey wheels touching the cassette teeth? Sounds like. You have to adjust the b-tension screw.
I would concur with frOsty re the free hub, check the exploded diagram for the hub assembly and re-assemble as per drawing, if its a Hope, make sure you fit the spacer on the axle before the freehub!
The retainer ring on my set up felt a bit lumpy at first, it went after a couple of rides.....the retainer ring actually does try to retain the chain!
Good luck !
I'll check the freehub. It is a Hope and I had to get my lbs to remove the old cassette and think the freehub came off with it some may have something to do with it.
No teeth touching anywhere. Thanks for the advice and apologies for posting in the wrong forum.
There's a seal on the back of the freehub body - sounds like that's not seated properly.
Njee - spot on. Still sounds a but rough but probably won't notice above me huffing and puffing and my creaky knees lol
