Scott Ransom: The S...
Scott Ransom: The Super Trail Bike
There's a lot going on with the new Scott Ransom. But in a nutshell it is a mountain bike with 170mm of travel, progressive geometry, and a 6-bar rear ...
By ben_haworth
Get the full story here:
https://singletrackworld.com/2024/10/scott-ransom-the-super-trail-bike/
Posted : 14/10/2024 10:31 am
greavo, johnhe, greavo and 1 people reacted
I'll get in before the haters - I own a Spark and I can honestly say, the hidden shock and cables have really not been an issue. The shock stays clean and happy but is as easy to adjust as on any other bike (it takes 3 seconds to remove the cover) and the through the headset cable routing has actually been easier to manage than most internal cable routing systems - you have such a massive hole to thread the cables through (an entire 1.5" headset sized hole, compared to a 4mm cable sized hole) that it's straightforward to recable the bike. The extra time spent dropping the fork is saved by not faffing about with miniscule cable ports.
Posted : 14/10/2024 11:11 am
Sort of surprised the top end models aren’t using Live Valve to do away with that left hand lever fest
Posted : 14/10/2024 12:02 pm
Have they actually bothered to add any weather sealing to the pivots?  Every Spark, Genius and Ransom I've worked on had no sealing at all, so the bearings had a pretty miserable time.
Frame hardware on the above were all made of cheese too, so most main pivot axles were drilled out, as the torx would strip out.
Posted : 14/10/2024 12:05 pm
Everything I hate about modern bikes in one expensive, easy to avoid package. Thanks again Scott, you nail it every time.
Posted : 14/10/2024 4:57 pm
When you want people to think your ebike battery has run out.
Posted : 14/10/2024 5:22 pm
Are the stw Servers running really slow?
It's a 2024 model year bike in holdover for 2025.
Posted : 14/10/2024 6:56 pm
In previous years a 170mm bike would be purely an enduro bike. Possibly a bikepark bike. We’d say that the new Scott Ransom can definitely still be pressed into enduro race duties. But it’s rather too, shall we say, ‘sophisticated’ to be a bikepark shredder. Yet we principally think it behaves perfectly well as a trail bike. Dare we say ‘all mountain’ bike?
Or maybe Super Trail bike?
Cool, thats made it crystal clear then.
Posted : 15/10/2024 9:40 am
wheelsonfire1, happybiker, happybiker and 1 people reacted
Haha, "all-mountain" would have been fine. Or we used to call them "long-legged trail bikes". Not usually a compliment.
Posted : 15/10/2024 9:49 am
We definitely need more sub-genres for what is a "mountain bike".
Posted : 15/10/2024 11:03 am
I like the idea and it looks great but not being able to change the bars is a definite deal breaker and damn it's expensive!
Posted : 15/10/2024 12:24 pm
You can run other handlebars - You need a new headset cover which is £15 then you run whatever you like.
Posted : 15/10/2024 12:32 pm
So, is it a crossduro or uptrail bike?
Posted : 15/10/2024 12:37 pm
Looks like an ebike
Posted : 19/10/2024 11:58 am
