Zwift (MTB) setup
Zwift (MTB) setup
I'm finally trying to get my fat arse back into gear and shed some weight/get my fitness back.  I've been struggling with motivation and actually finding something I'll stick with and have finally decided to sort out a proper turbo/Zwift setup using my Orbea Alma.
I plan to get a direct drive trainer (Saris H3) and use my Orbea on it as a permanent fixture but I'm looking for setup advice.
I'm thinking of a tablet mounted on the bars running Zwift, or some other interactive software.
Is there anything I should look out for, or any tips on setup?
Posted : 29/09/2024 8:38 pm
richmars and richmars reacted
 DrP
Get good airflow over you.
Fans..windows etc.
It'll make a huge difference to comfort and performance.
DrP
Posted : 29/09/2024 9:05 pm
Like @DrP good air but also think about what software you use. I started out on Zwift but for me I found Rouvy better.
Both do just ride along and training, but (for me) Rouvy held more interest as you ride in a real life video as opposed to video game (plus Rouvy has gravel / offroad tracks too!) - but we're all different.
I found going to the MTB meant racing was out as you don't have the gearing for it, but I did find upping the front chainring helped me to get more from it, again we're all different.
At the end of the day riding the bike and training is better than not riding the bike.
James
Posted : 29/09/2024 9:08 pm
 Kuco
Same as  fatbikeandcoffe, when I used a mountain bike on the trainer I stuck the biggest chainring I could fit as you’ll soon spin out.
Posted : 29/09/2024 9:16 pm
I think I've still got my old fan knocking about, so good shout 🙂
I'll have a look at Rouvy too, I'm not too fussed about racing really. It's just for me to get some sort of mid-week training after work.
I was looking at Apple TV as a way to get Zwift running but it might not be ideal if I decide on other apps? Maybe stick to some sort of tablet?
Posted : 29/09/2024 9:17 pm
Mincer and Mincer reacted
Buy one from a pawnbrokers or something, £30 as a cheap experiment.
Atv, cheap telly and a big fan is a winner for winter evening in shite weather.
Posted : 29/09/2024 9:22 pm
CeX has the 1080p 4th gen Apple TV for around £50 and I have a spare TV knocking about.
Just checked and Rouvy is also Apple TV compatible so that's good!
Think this is the plan then so far 🙂
Posted : 29/09/2024 9:34 pm
Can the saris take a Zwift cog? Solves all of the gearing issues associated with running an MTB as it gives you a virtual 24 gears. Does mean you're having to use Zwift but (cost aside) that's not the worst thing in the world.
Posted : 30/09/2024 9:43 am
I run a 44T on the MTB (which never goes outside) and that gives me enough gearing for say 300w at 75 cadence in gear 9 out of 10. When i had a 38T i basically only used the smallest cog.
Posted : 30/09/2024 9:48 am
Another recommendation for Apple TV and airflow via fan.
I found the fan I got from Amazon made me too cold initially, but I didnt want to get off the bike to turn it on, I picked up a wifi plug so I could turn it on 5 or 10mins into the ride when it was then needed via my phone.
Posted : 30/09/2024 11:56 am
I'm not sure about the Zwift cog, I did see some of the Wahoo ones could be bought with one, but they were mega expensive.
I think I'll probably get a better fan from Amazon too for the weekend as my old one is quite, well... old.
Gearing is something I guess I'll figure out, but I won't be racing really. I just want something interactive to train on during the week.
After a few rides on the newly built gravel bike, I'm starting to come to the conclusion that I just can't seem to get on with curly bars 🙁
Posted : 30/09/2024 5:31 pm
My setup. Works perfectly fine. Gearing isnt issue for ERG workouts on Zwift. If you're doing a general ride you'll ride at MTB pace rather than road bike pace. Either way it's all good.
IMG_20240930_191121962
Posted : 30/09/2024 7:20 pm
weeksy and weeksy reacted
 J-R
If you’re doing a general ride you’ll ride at MTB pace rather than road bike pace
Which means without the resistance of MTB tyres you’ll be spinning out at relatively low powers.  Many of us would not consider that “all good”.  In which case the bigger chain ring will fix that, as others have suggested.
Posted : 30/09/2024 7:25 pm
Saris doesn't work with Zcog unfortunately.
Posted : 30/09/2024 7:35 pm
I've just finished an hour ride on Zwift. The route finished with a 500m sprint. I hit 500 watts at 50 km/h, and was nowhere near spinning out. That's with a 30T front chainring.
Posted : 30/09/2024 7:41 pm
What kind of rpm were you hitting to get that? But also 500W isn't huge power particularly If you do want to have a go at racing.
If you just want to pootle it's fine to use mtb gearing, but you will be down the small cogs permanently. I even ended up getting rid of my compact road chainrings for standards when they need replacing.
Posted : 30/09/2024 7:49 pm
weeksy, J-R, weeksy and 1 people reacted
Saris h3 is great for erg workouts.
Posted : 30/09/2024 8:07 pm
500W isn’t huge power particularly If you do want to have a go at racing
Yes, but the statement was
Which isn't correct
Posted : 30/09/2024 8:12 pm
 J-R
Posted : 30/09/2024 8:15 pm
128rpm
Do you all want to see my biological passport too?
Posted : 30/09/2024 8:35 pm
davros and davros reacted
 J-R
128rpm
I’d call that spinning out.
Dont be a silly boy now.
Posted : 30/09/2024 9:05 pm
