Zwift iOS and a Bko...
[Closed] Zwift iOS and a Bkool Pro
I have a garmin hrm, which is ANT+, so is there any way to use an iPad or am I stuck using a laptop?
Posted : 14/12/2016 5:20 pm
No idea Andy - I have the same problem!
My iOS app crashed halfway through a session yesterday, so I'm going back to the laptop...
Posted : 14/12/2016 5:45 pm
AndyRT, for ANT+ on an iPad you need an ANT+ adapter...
And you'll likely need a lightning to 30 pin adapter too unless yours is an old iPad. TBH it's much less faff just to buy a bluetooth HRM. Some do both bluetooth and ANT+ (like the Wahoo one.) Some are bluetooth only (like the Polar one.) I have the Polar one, works well.
Posted : 14/12/2016 5:49 pm
I have just been looking at the viiiiva?
Posted : 14/12/2016 6:11 pm
Probably work fine as a BLE HRM but if you want to use the ANT+ to BLE bridge feature then you need to check that Zwift supports it. I know Trainer Road doesn't but no idea if Zwift does. If you don't want to use the bridge feature then it's quite an expensive HRM.
Posted : 14/12/2016 6:29 pm
Cheers Mr Blobby.
Sage advice.
Posted : 14/12/2016 6:54 pm
iOS Zwift [b]does not[/b] support an Ant+ adapter. I tried it with my Wahoo 30pin one that I use via a Lightning adapter with TrainerRoad. It's Bluetooth only on iOS. Luckily my trainer does Bluetooth power/speed/cadence, so I just needed to get a Bluetooth HRM. Got the Wahoo Tickr.
Posted : 15/12/2016 2:59 am
Is anyone using the Bkool pro with iOS Zwift?
Posted : 15/12/2016 7:21 am
I'm using a 4iiii Viiiiva HRM as a ANT+ to BLE bridge so I can connect my Power2Max powermeter to Zwift iOS running on my iphone.
Once the HRM has woken up and is streaming BLE data (power, speed & HR) to the 4iiii app, disconnect Viiiiva in the app and then start Zwift. All the data can then be seen by Zwift and you can pair in the normal way.
It sounds like a bit of a workaround but it's the easiest way I've found to get ANT+ data onto Zwift iOS.
Posted : 15/12/2016 10:09 am
Interesting stuff that it supports the bringing in the Viiiiva. An alternative could also be the Wahoo RFLKT+ that also supports ANT+ to BLE bridging. Be curious to know if that works too, might give it a go later.
Posted : 15/12/2016 11:33 am
my RFLKT+ was pretty unstable just on bluetooth, can imagine it would get any better bridging some ANT+ sensors too...
Posted : 15/12/2016 11:35 am
I've only been using the Viiiiva/Zwift iOS combo for a total of ten hours, but in that time the connection has been rock-solid.
It seems that Zwift also recommend Viiiva [url= http://zwiftblog.com/ant-ios/ ]here[/url] for connecting ANT+ sensors.
Posted : 15/12/2016 11:53 am
Viiiiva ordered
Thanks everyone
Posted : 15/12/2016 3:17 pm
