Zesty Maxle Convers...
[Closed] Zesty Maxle Conversion
I'm running a 2011 Zesty 314 and wondered if anyone new if its possible to swap out the standard axle drop-outs and fit new drop outs which would accept a bolt-thru back axle?
Posted : 12/02/2012 7:32 pm
Can you weld? If so then converting to a maxle setup is doable. Otherwise, 10mm thru-axle will work in standard dropouts. But why?
Posted : 12/02/2012 7:34 pm
The dropouts on the Zesty aren't removable, are they? You'd need a whole new seatstay assembly.
Posted : 12/02/2012 7:35 pm
The replaceable mech hanger is removable, but it also acts as a locating point for the wheel. The non-drive side locating point is also removable
Why - to stiffen the back end up
And yes, i've welded in the past, but it looked more like pigeon droppings than carefully engineered metal fusion!! ๐Ÿ˜€
Posted : 12/02/2012 7:48 pm
If your hubs allow it, you could get a 10mm bolt in (or through) axle that would amount to pretty much the same thing.
Posted : 12/02/2012 8:05 pm
boltonjon - Member
Right - the newer models have a different setup then.
Posted : 12/02/2012 8:17 pm
OK, stupid idea - just been fettling and see that the attachments for the drop outs are two tiny, maybe 3mm, screws holding it on to the frame.
If there was such a kit, then they'd be the main stress points, and i highly doubt they'd take the strain
Stupid idea!
Posted : 12/02/2012 9:12 pm
