Mine;
At the age of about 15 having grown out of my bike I decided to see if my dads would fit. I decided it would but didn't like his saddle and wanted to transfer the one from my bike.
I didn't realise/think that the saddles might be swappable between seatposts so decided to fit my seatpost to his frame.
So I spent a happy afternoon bashing the top of my seatpost with a 2lb hammer in an effort to make it fit into the 'slightly too small' seat tube on my Dads bike.
Eventually the frame split down from the seatclamp slot.
Being a coward I shoved it to the back of the shed and didn't say a word. It was about 2 years later I was presented with the results and asked to explain.
More recently I managed to refit the lowers the wrong way round when servicing my forks although that was relatively easily resolved.
mmmm, my worst has to be when I was about 10, my dad asked me to measure the flex on a storage heater and cut it down to length so he could then re attach the plug,,, somehow I thought it best to plug it in before I cut it.. 😯
In my old job as an ATM security engineer I was training 10 staff with a live atm on how not to activate the ink sytems when working on a machine.
I forgot to diconnect the firing mechanisms............ thus destroying £250,000 cash infront of the customer ;-0
FAIL
In early 2004 I needed a new CSU for my fox forxs due to worn stanchions. In my eagerness to fit them and get riding (had a big ride the following morning)I use the old set to mark the correct height steerer and proceeded to cut.
It was only after that I realised I had made the cut on another incidental mark on the steerer and it was about 2 inches too short.
120 quid down the toilet in the time it takes to wield a hacksaw.
stipping BB threads by brute force, and also the sump plug on my RD350YPVS 😯
i own a torque wrench now
Fitting a new shower to the mains, assumed the 2 stopcocks in the bathroom would isolate it just cracked the nut a touch to be careful, never found the nut, spent ages while trying to divert water into the bath trying to figure out where the stopcock was!
Turns out the plumbing was bodged so that any stopcock was fitted after the shower so I had to get a neighbour to turn it off outside at the mains!
So the bikes upright and i'm cutting round the old non-locking style grips with a stanley knife. Get about 80% of the way around and the blade flys through the last part of the grip. It's at this point i realised that i'm cutting up, towards myself with quite lot of pressure, Stopped about an inch from my own neck!
Had to go and have a quiet cup of tea and a fresh change of pants after that. Used lock-ons ever since!
+1, How easy it to that?!
went to unscrew the immersion heater plug off my old water cylinder only to find it seixed. leaned into it and basically tore the whole section out of the top of the tank.
bum.
Overtightening the shock eyelet bolt on my old 2004 FSR and sheared off the thread - replacemnt rocker from BETD £100 - oops 😳
The glue didn't set properly once on a puncture patch....does that count?
Is that becuase you don't do any maintenance 😉
first couple of times I tried to bleed brakes were messy
not a mechanical fail as such, but having proudly changed cog and retensioned the EBB on my Tinbred, I briefly span the cranks while prodding the chain to see if it would derail under sideways load, and found suddenly and rapidly that there certainly wasn't enough slack to fit my finger inbetween the chainring and chain.
I did find that a new On-One ss chainring's teeth are sharp enough to go through a nail though.
1.5 years without a punture went for a ride last sunday front was flat withing 5 mins of leaving hut opened tyre to see a presta valve cap rolling around in the tyre been in there with same tube still have no idea how it got in there tho lol
on my bike-open both ends of the brakes and basically topping up the floor for fourty minutes.
Generally - Unscrewing my plumbing much further down through the lateral torque of trying to unscrew a tap to change a washer, result being my dog dancing about in the kitchen under the ensuing indoor rain coming through the lights.
Recently stabbed myself in the chest with a Stanley knife while trimming the sole of my new MP66s to fit the cleats.
LOL
Near avoidance - routing out a bass guitar body to fit new electrics, was only when I finished I noticed how close the strings from my hoodie were to the bit rotating at a million RPM.
If it had caught I have no doubt it would have guided the router straight into my adam's apple.
Ha ha - just narrowly avoided another.
Fitting a new external BB this evening gave me a great chance to try out my new torque wrench. Dialled up to 50nm, my eyes are bulging as I try to torque it up sufficiently to get the wrench to click.
OK, I think, I'll do the other and see what that's like. 'Sensibly tight' by old standards and 'clack' there it is!
How odd, I think.
One quick RTFM later and I find that the wrench only works on a normal thread. The reverse thread of my drive side still has to be guessed.
Anyone got any spare 2.5mm spacers? I was so tight on the drive side the cup was still going in and stretching the spacers aside as it went.
oops!
I fitted a brand new set of square taper deore cranks on my work bike. Whilst tightening said crank arms the doorbell rang and off I trotted to answer it. On its maiden voyage I discovered that the none drive side crank bolt was not tightened and stripped the inside of the arm out.
Stunning. Never even got off the front garden. The arm was ****ed.
Ah, it's not just me then. I tore a chunk of fingernail off with a screwdriver doing just this the other day. Then snapped a Stanley knife blade in two and the broken bit catapulted wildly through the air inches from my eyes. It's seemingly an enterprise fraught with risk and potential haemorrhage.
Back when I rode BMX, I was trying to remove my Profile cranks to put them on a new frame. The crank puller I had was more confusing than calculus, and after I finally figured it out, I neglected to tighten the tool into the arm. Needless to say I didn't learn my lesson after stripping the threads on one arm, so I stripped 'em on the other too. Took me an hour to cut through the toughened spindle with a grinder (after trying everything I could think of without destroying them).
More recently I tried to fix my mum's cheapo pressure washer (she was prepared to bin it, but I figured I'd give it a go). Trust me, getting two pints of water pump oil out of wooden garden furniture and brick patios is difficult.
you're not a real bicycle mechanic until you've sawn a steerer too short.
Made my front brake hose too short DOH!!
Also had a crank puller malfunction many years ago as an eager 16 year old 'expert mechanic'(or so I thought on my first Muddy Fox, the lmtd edition red one).
Screwed the puller in nice & tight, then spent 20 minutes with my wimpy muscles swinging on the spanner, achieving nothing but starting to strip the extractor thread.
Utters some mid-pubescant profanity, unscrews puller, finds 14mm crank bolt still in place.
Mmmmmmmmm, that'll be the problem then..........
Quite minor other than the timing, my back wheel dropped out halfway round McMoab last weekend. Luckily it did it on a nice easy bit and didn't just fire me off a precipice
I got most of my spannering disasters out of my system on my first motorbike, almost wrote it off with an 8mm spanner once.
i broke a spanner the other day trying to get my pedals off, then turned the new spanner the [u]correct[/u] way
Refitted a cam belt one notch out. Whirr- clunk. Top end rebuild- bugger.
Enrolled in college in an effort to get my youthful life back on track (aged 20). Borrowed my Dad's cheapo commuter bike, and in an effort to appeal to the kool kidz I stuck a set of BMX handlebars on it.
Second day, home time, and I forged a path between the many studes onto the main road between two parked cars. Saw a car coming and hit the brakes - BMX handlebars swung forwards / downwards at high velocity, coming to rest on the front wheel, but not hard enough to stop the bike which continued onto the main road.
No choice but to deliberately fall over onto my side (harder than you'd think)... Came to rest with my head inches from the passing car - everyone laughing - never went back to college...
Back when I was 16 I was cleaning the chain on my 50cc Suzuki by leaving the engine idling in first whilst the bike was on its stand. I held a rag to the slowly moving chain and then screamed very loudly as it snagged and dragged my index finger round the rear sprocket. To this day the last 1/8th of an inch is solid scar tissue.
I was levelling my living room floor joists last year. I went to put in a 120mm screw diagonally through the joist into the plate. Impact driver slipped out of screw head and landed plumb onto my thumb nail (where I was holding the screw). I didn't quite release the trigger in time, and therefore impact drove (is that the correct term?) a #2 posidrive bit into my thumb nail. ouch.
that was may last year. got about 3mm of black stilll to grow out from my thumb nail!
Never done the steerer tube too short thing, but close to it.
Stripped, cleaned, reassembled and fitted to bike a chainset that then failed to work; took a few moments to note that I'd reassembled it granny/outer/middle... that folly was beer assisted.
Had to send an RP23 (same bike, actually) back to Mojo with a begging letter after I'd wondered what the grub screw with the white ball jammed into the hex socket was; it certainly released something once I'd prised the ball out and vented it. Bike didn't ride too well next day.
Just spat out some tea reading user-removed's epic!
Stripped the crank extract threads out of the LH crank on a bike a few years ago, so ended up using a fork type ball joint splitter & a lump hammer every time i needed to get the crank off (which i probably did about 5 times without a problem).
Fitted my boxfresh elixirs to my bike, bought a bleed kit to cut down the lines a bit. All going fine until the piston spacer dropped out without my knowledge. Pumped lever as per instruction and fired pistons across the garage and brake fluid pissed everywhere!
My worst fail was removing the gearbox from a car. I didn't fully appreciate how heavy it was and how hard it is to support it's weight by hand while lying under a car. As I removed the last mounting bolt the full weight lammed down on my hand and I was trapped there shouting for help as I couldn't move it off my hand...
Cut the steerer too short on my 2009 revs. I had measured at least 4 times. 😯
Luckily there was just enough that a lower stack headset and stem did the trick. 2mm of spacers too!
Extra low front end compensated for with unfashionable risers.
Now I feel good about being a moron. 😀you're not a real bicycle mechanic until you've sawn a steerer too short.
There is not enough space on the internet for my list of 'events' so one from my Dad.
Using a scalpel to cut some paper while having the telephone propped between his ear and shoulder. Phone slips so he goes to grab it stabbing the scapel straight into his arm severing an artery and squirting blood across the office and several colleagues.
lol @ solamanda, just spat my porridge over the monitor!
Removing raw plugs from a wall, the obvious tool of choice was a screw driver. Two mins into the job and I had a screw driver stuck in my face. Straight through the side of my nose and imbeded in about an inch. I was a little concerned with the situation, my wife was busy laughing and reminding me NOT to get blood on the carpet.
I get a man in these days for such taxing jobs
Years ago I was cutting the gaiter off a moped fork with a Stanley knife, I cut down and went straight across the palm of my hand that was holding the fork leg.
At this point my mate brought me a cup of tea, I put my hand out to get it, and then I saw the 5" cut...
Wasn't deep, but I jumped more when the nurse 'splashed' it with stuff.
Other than that, destroying the rear caliper on a Peugeot as I didn't realise that the pistons rotated in/out - consequently I was just trying to 'push' them back in.
i tried to fix what i thought was the cheaper rate electricity switch unit but was fired across the room into the wall and knocked out. Turns out when electric company came out it was where the mains came in the house and was huge voltage and i blew the local substation too 🙂
Bike wise i wanted a new rim on my ss wheel so thought id help the shop out by cutting the spokes. Turns out i couldnt get the spoke bits out as the freewheel was still on 🙂 and i couldnt get it off with no wheel to hold on to . It took a big vice and lots of damage to the hub to get the cog off 🙁 needed a new cog too and took ages longer . Bugger
Did the same firestarter while still in my pre-pubescant 'expert mechanic' stage. Took hub to shop with freewheel still on and hedgehog-like spikes all round from chopped spokes.
Oh well, its how we learn I suppose.....
Not bike related:
I worked a summer in a small machine shop, often left alone. One simple job was using a big ancient lathe to cut-to-length and shape some bar. While using the chuck key to secure the bar, I managed to brush the power knob, engaging the lathe.
In a fraction of a second, the key was under the chuck, sheared off on the bed and flying through the air at warp speed. By good fortune, my hand was palm-down so I let go, otherwise I would have lost it. And the flying chuck key could have impaled me too!
LMAO at Mantastic's wife. Very supportive 🙂
Managed to put some brake pads in the wrong way round on the car once. Metal to metal contact not best way of a stopping car! ****ing eejit!
