Yeti 575 and Thule ...
[Closed] Yeti 575 and Thule 591 ProRide roof rack
Does anybody know if a Yeti 575 with Reverb post will fit ok on a Thule 591 ProRide roof rack ? Not sure if the hydraulic cables will be affected ? ๐Ÿ˜•
Posted : 20/06/2012 9:00 pm
The proride has a recess in the mount for cables and things on the downtube so it should be fine. I normally wrap some bubble wrap around the frame to so it doesnt directly clamp onto the frame
Posted : 20/06/2012 9:11 pm
I assume you have a new 575 as you have a dropper post.
I have the original style 575 (27.2 seatpost) and it does not work well with a 591 due to a cable boss towards the bottom of the downtube. They may well have changed this for the later models.
Posted : 20/06/2012 9:13 pm
Yes - its the 2012 575 so perhaps there are changes?
Wrapping bubble wrap around the frame might also be a solution to stopping paint rub - thanks for the feedback
Posted : 20/06/2012 9:54 pm
 ben
It'll work fine.
Posted : 21/06/2012 6:14 am
