(Yet another) 2x9 q...
[Closed] (Yet another) 2x9 question
I've got 3x9 on one bike at the moment but prefer the 2x10 on the other bike. So I'm considering going 2x9 as a cheaper option than getting a full new drivetrain. Can I just fit a double chainset and use the current shifter and front deraileur,by adjusting the stops. It seems it might work ,but would like to know for sure before I start messing about with it. Cheers
Posted : 21/09/2012 4:52 pm
Yes.
Posted : 21/09/2012 4:53 pm
Yes, I did that. Takes a bit of patience setting the stops but works ok.
Posted : 21/09/2012 4:57 pm
 Moe
Works fine on my Xtc, took the opportuninty to fit an external BB and shorter crank arms at the same time.
That was fun to explain to OH, £15.00 for new cart BB or £130 for dual rings and externalBB! 🙂
Posted : 21/09/2012 5:27 pm
THe only thing to check is the difference in chainring size you want. Most Shimano ones only cope with a 12t difference. They do 1 SLX one that copes with 14 T difference so as I wanted 22/36 I ended up buying a new front mech as the original couldnt cope.
Posted : 21/09/2012 5:33 pm
No need for a whole new chainset, just remove the big ring and maybe change the middle one if its a bit too spinney...
Posted : 21/09/2012 10:54 pm
