Ye Olde axs mech co...
Ye Olde axs mech compatibility with axs t type chain and cassette
Eyup,
So we're away riding this weekend and my t type mech battery pogo pins have started playing up causing intermittent battery connection issues. I've 'sort of' got it working but I want a mitigation strategy.
I have a udh hanger and I have an older axs non t type mech.
If I take those bits along as a backup, will it work with the t type chain and cassette?
I also think I'll need to pair the shift pod and the mech but I'm pretty sure that's doable easily
ย
Ta muchlyย
Posted : 19/03/2025 1:24 pm
Try giving the battery terminals a buff with a scratchy think or a wire brush (carefully).ย  Can sometimes be tarnishing on the terminals rather than the pins.
Posted : 19/03/2025 1:29 pm
I'm going to guess it will work...but not tried it.
Just pair the old mech with controller and it should be fine...you'll need to set b-tension and micro-adjust but those are easy to do as well.
Posted : 19/03/2025 1:48 pm
Thanks, I don't think it's tarnishing (had that before) - one of the pins isn't very springy anymoreย
Posted : 19/03/2025 7:56 pm
^ Apologies if a sideways comment but, I'm sure somebody posted on the STW forum somewhere about how to fix and somewhere that would fix stuck pins.
Posted : 19/03/2025 8:13 pm
The t type sits further outboard than non t type . So check the old axs if it has enough micro adjust to make shifting work. I went the other way an used a t type mech with standard chain and cassette and it's on the limit...
Posted : 19/03/2025 9:08 pm
I thought it was a no go, t type chain and cassette won't sync well with old axs mech🤷
Posted : 19/03/2025 9:23 pm
