Yari - pressures an...
[Closed] Yari - pressures and tokens ?
[#9939744]
i have a 130mm Yari (2017) on my Bird Zero TR. Weighing around 12.5 stone I have it set at 75psi which seems to work sag wise but I rarely, if at all, get the last 20mm of travel. Looks like it comes setup with 3 tokens, so have just ordered an EpicBleed 24mm spanner to have a play with tokens.
Any advice ?
Posted : 12/04/2018 9:23 pm
Ger rid of some tokens and air.
The MoCo damper gives the Yari a more progressive spring rate than Charger damper equipped forks.  I'm running no tokens and still had to dump a few psi out of mine at BPW last weekend as I was still short of 25mm-ish travel.  Was at 22-26% sag, now 30%.  Loads better after that.
Fancy a Luftkappe next.
Posted : 12/04/2018 10:32 pm
I echo the remove tokens advice. Went from 3 to 1 and if I still had the fork would’ve tried it with none - 160mm travel version.
Posted : 12/04/2018 10:39 pm
Thanks, will go down to 1 and see how it goes
Posted : 12/04/2018 11:11 pm
I am 14st, running (I think) 90psi and 1 token.
It came with three in, and two spare, but I found it was OK on smaller bumps but ramped up quickly so I did not get full travel unless *battering* into things. Removing down to one needs a nudge more compression damping, but it is a much more fluid fork now.
Posted : 13/04/2018 12:07 am
matt, good to know, we ride similar stuff. Will drop down to one next week once I get the spanner. Off to Feshiebridge for the weekend with Riderz tomorrow....
Posted : 13/04/2018 12:11 am
Interesting to read this as I've had similar thoughts about my 130 Yari. Not sure how many tokens are in but I've ordered a socket so I can investigate.
Posted : 13/04/2018 9:28 am
I’m on a 160mm Yari and I’m about 12 stone, not sure what pressure is in there at the moment - maybe around 70 psi.
My fork came with 2 tokens and I’ve taken them both out and I’m still not seeing the last 20 / 25mm of travel. Not sure I want to take much more air out as they already feel fairly soft / I think sag is around 30%. Running compression damping wide open.
Thinking about getting a charger damper for the fork or maybe a Yari Up fast damper. Funds not allowing it at the moment though.
Posted : 13/04/2018 9:39 am
<div class="bbp-reply-author">joemmo
<div class="bbp-author-role">
<div class="">Subscriber</div>
</div>
</div>
<div class="bbp-reply-content">
Interesting to read this as I’ve had similar thoughts about my 130 Yari. Not sure how many tokens are in but I’ve ordered a socket so I can investigate.
</div>
the online manual suggest they come with 3, and 2 spare in a bag.  Will see when I open mine up !
Posted : 13/04/2018 9:44 am
I'm running the 150mm 29er Yari, got 80psi in and 1 token. Weigh 11 stone.
Did have 70psi and 2 tokens, but feels much better now. Still plush, and utilising most of the travel on big hits.
Posted : 13/04/2018 9:48 am
An extra thought on this - that last 20mm of travel I only reach on drop-offs and jumps*, most of the time I am getting like 90% of the travel, and now happy with  that. More importantly, the fork is more linear and fluid overall..
*check out teh gnarlz, bro.
Posted : 13/04/2018 9:51 am
95kg and running no tokens. Always had travel left over even when running softer than I would have liked. Turned compression damping up a couple of clicks for more support on slow steep stuff. Feels much better on slow and fast stuff.
great info, thanks.  Will go down to one token initially.  I have the compression damping just on the fast side of halfway, so will keep an eye on that too.
Posted : 13/04/2018 9:56 am
Update - the spanner arrived from EpicBleed and I took 2 tokens out earlier, leaving 1 in. I upped the pressure a little to 80 psi to get around 25-27% sag. Took it for a spin at Cathkin and was using all bar the last 10mm of travel, so pretty happy with that. I reckon I’d bottom it easily on a big hit.
Thanks for all the info and advice.
Posted : 16/04/2018 10:08 pm
Happy days...
Posted : 16/04/2018 10:16 pm
Cheers matt, thanks for the help.
Posted : 16/04/2018 10:33 pm
Tftuned have the fast-suspension damper, I think it's £130 (not the more expensive Yari up)
I have a similar novyparts one and it's made more of a difference than fitting a luftkappe.
Plusher, more grip, uses all of the travel without feeling divey
Posted : 16/04/2018 10:50 pm
Got a linky to that - can only see the Yari Up.
Posted : 16/04/2018 11:10 pm
It's this. (Google translate is yet friend)
https://www.mrc-trading.de/Fahrwerk/Tuning/FAST-compression-kit-Daempfungseinheit-fuer-RockShox-Yari.html
I emailed tf and they had some in stock a couple of weeks ago
Posted : 16/04/2018 11:21 pm
