XTR Shifter stripdo...
[Closed] XTR Shifter stripdown guide anyone?
[#3568753]
So my LH (xtr 970) shifter wouldn't drop the chain cleanly to the granny today. Seemed to be dropping the mech to the low stop though.
When I got back, after cleaning the bike popped it in the workstand & took a quarter turn off the Low stop & that seemed to do the trick.
Was testing changing up & down through the triple OK when it just stopped changing down. At all. Chain is on the big ring and the shifter lever seems to move freely but with no resistance and no effect.
So before I operate, will springs fly off in all directions? Has anyone seen a guide or is it relatively easy to dismantle & reassemble.
Posted : 16/01/2012 12:40 am
Are you sure it's not just dirt in the cable?
Posted : 16/01/2012 12:42 am
 mrmo
Not tried an XTR but the general rule with Shimano shifters is do not take them apart, it will end in tears.
Posted : 16/01/2012 12:45 am
Not completely no, but if it were that I would expect to feel the lever engage and see no release. I can't feel the lever engage.
I'll check the cable is free tomorrow night, cheers.
Posted : 16/01/2012 12:47 am
Oh dear. Started, then stopped... 😕
Posted : 16/01/2012 12:48 am
Johnny Panic - Member
If the spring on the mech isn't strong enough to overcome friction in the cable - and hence put a load on the shifter mechanism - it can feel exactly as you've described.
Posted : 16/01/2012 12:52 am
I think I can see what you mean.
Fingers crossed you're right.
(And I that can get the bolt & screws back in)
Thanks.
Posted : 16/01/2012 1:07 am
Mine wore out just like this. Started missing down shifts and got worse and worse until no shifts. Bike shop pulled it apart for fun but it was worn out and they did not have donor parts.
Posted : 16/01/2012 1:08 am
[url= http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/SL/EV-SL-M970-A-2777_v1_m56577569830637994.pdf ]The Parts guide is here[/url] but how old are your shifters? if under 3 years, they are still under warranty, why not just send / take them back to where ever you got them from for service.
Posted : 16/01/2012 1:14 am
Unless second hand...
Thanks for the link - helps a bit.
Posted : 16/01/2012 1:27 am
Chances are that it's a small pawl that's got gummed up, to rectify this you only need to remove the plastic cover(no need to dis-assemble the mechanicals), dribble some GT85 onto the pawl's pivot, and work it back and forth until it's spring will operate it by itself.
Posted : 16/01/2012 8:52 am
Thanks to all.
Working again now.
Took the lid off, cable was free so not that.
Couldn't actually see any problem but after applying GT85 and working it a bit it's now behaving properly again.
Cheers!
Posted : 17/01/2012 1:08 am
