XTR Pedal not tight...
[Closed] XTR Pedal not tightening
Like the title says, one of my lovely new XTR pedals ain't tightening past a small amount, no matter how much I turn the adjuster (both sides). The other pedal is fine. I've turned the adjuster bolts to the limits a couple of times each to see if it just needed working in, but no joy. Is this a common issue, or am I being a bit of a 'tard?
Posted : 18/05/2010 2:11 pm
Anyone?
Posted : 18/05/2010 4:15 pm
The screw moves the spring no? Work out why it is not doing so? Should all be visible Shirley?
Posted : 18/05/2010 4:16 pm
Everything looks like it's behaving, hence the confusion. Going to LBS it...
Posted : 20/05/2010 4:22 pm
