XTR M985 brakes lea...
[Closed] XTR M985 brakes leaking at the banjo - advise needed.
 diz
My M985 XTR brakes are leaking at the banjo, has anyone fitted goodridge's MTB107 braided hose kit?
Posted : 03/02/2014 9:04 pm
On the Shimano banjo there are two very thin o rings which are quite easily missed out. Never fitted Goodridge so don't know if the banjo is the same but it must need some sort of seal - copper washers or o rings.
Posted : 03/02/2014 9:11 pm
Beaten to it, check you've not pinched/split the o-rings.
Posted : 03/02/2014 9:13 pm
 JoeG
The bano/caliper/bolt joints seal with o rings, so it would be an easy fix if leaking there.
Parts available [url= http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/BR/EV-BR-M985-F-3075A_v1_m56577569830772091.pdf ]techdoc[/url]
Posted : 03/02/2014 9:21 pm
 diz
Thank you. I will have a look but it looks to be leaking from the crimped part of the banjo where the hose goes in.
Posted : 03/02/2014 9:34 pm
Is it crimped on Goodridge? I thought it was tightened with a shroud nut over an olive? In which case you should be able to just tighten it up.
Posted : 03/02/2014 9:43 pm
 diz
No the crimped type is the original shimano one. I am thinking of replacing it with goodridge
Posted : 03/02/2014 9:50 pm
I seem to remember that there was a fault with the crimped end leaking, and being replaced under warranty, i'd contact wherever you bought them.
Posted : 03/02/2014 11:25 pm
