I am trying to fit a different chainring to an XTR chainset.
Issue I am having is with a Rotor Q Ring - the drillings on the ring are smaller than any crank bolts I have seen. Can you get smaller crank bolts or should I go back to Roter? They have already sent me the wrong set of bolts once.
Any help greatly appreciated!
absolute black? http://absoluteblack.cc/oval-96-bcd-xtr-m9000-chainring.html
Double post
The AB ones use the XTR bolt covers. The Rotor ones don't though as they are the wrong size.
I am a bit baffled!
XTR should be M7 bolts. AB ones support this.
you got the tabs with the Rotor one? http://www.chainreactioncycles.com/rotor-qx1-xtr-9000-narrow-wide-oval-chainring/rp-prod144596
There were no tabs with the Rotor ring. It was purely the ring and nothing else. Saddleback sent out bolts that don't fit the ring.
The M7 bolts don't even go through the drilled holes on the chaining. The standard 3 recessed holes are there. The LBS offered to drill it out. I am not keen on this idea having spent £90 on a chainring.
I've just looked at the CRC advert - there were no tabs in the packet. I am guessing that is what I need. I'll call the distributor tomorrow.
Thanks for that!
£90! yikes Bit cheaper here: http://www.velotechservices.co.uk/shop/vprod4.asp?cat=260
But no one else seems to show the tabs like CRC. XTR tabs are historically ridiculous in price though so maybe that's why and if you already have them then they just supply the ring separate.
tbh the rotor site doesnt have any information on the XTR specific fittings, the amount of useful information is something I really like about Absolute Black. Rings are cheaper too!
How much do you want to spend? http://www.carbon-ti.com/products/chainrings/x-monosync-titanium/x-monosync-ti-32-x-96
