IS this only required to remove the cranks?
Posted : 09/07/2013 10:49 am
Assuming you're talking about M970 ones, you only need the screw in tool to remove them. To fit you simply torque up the main fixing bolt (45-55Nm) and use the adjustment ring to remove play - there is another tool to grip the ring but it can be done without.
Posted : 09/07/2013 10:59 am
yes M970 thanks
Posted : 09/07/2013 11:18 am
