XT hub - swapping i...
[Closed] XT hub - swapping internals
Considering moving from qr to a 15mm front hub. I'm currently running XT - is it possible to swap the internals from a new XT 15mm hub into the existing hub, or are they incompatible? Not held the two of them up together, so apologies if this is a obviously daft question!
Posted : 20/08/2013 8:20 am
Shimano hubs are not convertable. You'll need to get the wheel rebuilt, if you can't do that yourself then it wont cost much more to get a new front Hope Hoop.
Posted : 20/08/2013 8:33 am
Cheers - suspected that might be the case. Not sure my wheelbuilding skills are at the required standard to swap out the entire hub.
Posted : 20/08/2013 8:41 am
