XT double / triple ...
[Closed] XT double / triple measurements again
Can anybody shed any light on if a middle ring on an fitted triple xt chainset will be in the exact same position (ie same distance from frame) as the outer ring on a double xt chainset?
the reasoning behind the question is I want to run 1x 10 and my chain device is fine with my current triple cranks but I like the look of the new xt double cranks but don't want to buy a new chain set just for the crank arms if the device will not line up properly.
Thanks in advance for any info.
Posted : 23/11/2012 10:17 am
 cp
no it's not in the same place. There's a spec sheet which describes chainline on shimano europes website.
Posted : 23/11/2012 10:18 am
I know the chainline is different but when I looked it up the chainline on a double is measured to the centre of the gap in the rings and on a triple it's the centre of the middle ring.
I hope that makes sense and that's why I am asking if the rings will be in the same location.
Posted : 23/11/2012 10:23 am
According to the Shimano tech manual these are the measurements from centre of BB to centre of rings for the two chainsets -
M780 triple 55.7, 48.2, 40.6
M785 double 50.2, 42.3
Posted : 23/11/2012 10:32 am
