Anyone else had this? I thought bike was clattering a bit more than usual then when I randomly looked down I thought I had the clutch switched off.... After the descent I checked and it was on... I released the switch and there was no tension switched it back on no tension the chain movement was exactly the same on or off
So I undo the screws on the cover and low and behold the inner clutch the thing that tightens up or slackens off has just shearded off , it's the piece of metal that you asjust the tension with a allen key has just clean shearded off .... It literally fell out when I opened it up.....
I've only had it about 5 weeks or so it was fitted by lbs and luckily bought at lbs, I'm truly hoping its a warranty issue????? Please some one tell me it will be
And it must have happened tonight as I lost the chain straight after for the first time ever with narrow wide front ring but it was a Rocky peak fast descent
Gutted mate. Where was that then, on the cheeky you were heading to?
You think you'll get it sorted for Sunday?
www.singletrackworld.com/forum/topic/clutch-mech-problems
Carlos no mate it happened just as I got to BoO heading back, proper gutted, should be fine mate for sun, ill just have to run the descents in 1st gear to keep chain tight ish lol, I'm hopeful shop will sort it before then, fingers crossed!
Realman that sounds exactly like mine then although mine wasn't adjustable as soon as i opened it up it just fell out that metal piece cleanly cut/shearded
Did you get it done under warranty pal?
Real man just saw your thread is from a few hours back ๐
Was thinking it was from ages ago!! Eerily creepy!
Yeah it happened a few days ago actually, just taken me a while to actually take it apart and find out what was going on. Emailed the place I got it from but haven't heard back yet, although expecting it to be pretty straight forward.
Bummer, take it youv'e not got a spare, but saying that the shops very good with stuff, so should get sorted.
I hope they don't try claim user error as I literally haven't touched mine since it was setup by lbs..... Truly gutted though, I can't understand how it's happened though not the foggiest
So has your cam/adjustment screw piece of metal completely come off like mine? So you can hold the piece of metal with adjustment screw one end and the circular bit at the other? That you can literally hold in your hand?
You can break a mech just as easily on its first ride as on its thousandth... I did one on Sunday along with twisting the hanger (with is unfortunately also the frame...).
No mate I sold the xtr one a while back ๐
It still works fine though shift wise it's just like a normal mech , I'm sure it will be ok worst case leaving it on for Sunday as I was descending BoO I was in 10 th gear so the chain was at its slackest I reckon ill be able descend Sunday fine as its mostly flat and smooth
Yeh I know but this has absolutely nothing to do with me bashing it it setting it up wrong something's gone wrong inside the mech , I'd accept it and take it on the chin if it was due to crashing or whacking it against something but it simply hasn't
just sent a few pics into the shop - its a week turnaround with madison, but thats if they will even warranty it ๐
luckily the shop have got a slx medium clutch they can fit me tomoz in time for BH riding ๐ it actually looks neater/nice than the xt IMO
hopefully it will get warrantied or im just going to bite the bullet and stick a full on xx1 group on my CC!!!!!!!!
really pee'd off i know these things happen and id hold my hands up if id mangled it, but its not even that old (5 weeks) and totally happened out of the blue ๐
Mine broke, just the same way as you described yours.
bit naff really!
wellywheels did you get it replaced under warranty???
Same here, mine broke in exactly the way you described after a couple of months. Previously to that it had loosened and I'd had to tighten it a few times. Replaced under warranty.
Following this mornings ride mine needs tightening up. Ive removed the cap- do i tighten the silver screw which has a bolt head? (Its not an allen screw as mentioned above). Theyre xt's btw
agentdagnamit - Member
nice! cheers, did you get a response as to why it happened? im sure it will get sorted
im going to buy the only slx medium cage one they have in stock at the lbs in the mean time and then probably get a refund from the shop for the xt one when it (hopefully!) gets replaced!
creamegg - Member
sorry cremeegg, its not an allen key, its a screw you need to turn, i was in late last night when posted the thread and tired, and pee'd off! just turn the screw to tighten it, you may need some really thin nosed pliers to get in there
Thanks
