XT 12 speed shifter...
XT 12 speed shifter failure
Went to shift into a lower gear at the start of my ride yesterday and the lower lever suddenly swung back with no resistance on it. Trigger still works to go into a harder gear and no way to shift back to an easier gear. So it seems the cable is still in ok but something has gone awry inside.
On a quick Google I got some hits referring to this failure being common ish in XT 12 speed shifters but hadn’t read this before.
Has anyone had this and found a way to fix it? I’m assuming it’s terminal but have a very cheap slx replacement on order from Merlin (so it won’t have the double shift up of the xt but is apparently a lighter shift as a result) so happy to dismantle it and have a play around to see if it’s fixable.
Posted : 04/05/2023 9:41 am
I had this and when I opened it up the cable nipple had mangled a bit of the insides so it went in the bin
Posted : 04/05/2023 9:45 am
Older style shifter, but I'd imagine it'll give you somewhere to start
How to fix a shimano shifter that won't shift - YouTube
Posted : 04/05/2023 9:48 am
Had an XTR one do the same, the spring that holds the ratcheting part had failed, had it warrantied by CRC
Posted : 04/05/2023 9:52 am
Ah mine is from 2020 so imagine it’s out of warranty - think it’s 2 years on anything other then dura ace or Xtr when it’s 3
Posted : 04/05/2023 12:05 pm
I had something similar, fortunately under warranty.
Posted : 04/05/2023 12:27 pm
My XT one failed too.
I haven't read the thread but some info here
https://www.mtbr.com/threads/shimano-xtr-m9100-shifters-keep-breaking-no-downshift-intermittently.1150763/
Posted : 04/05/2023 12:37 pm
Ha, I had two Shimano shifters fail in this way!
In 1999...
In those cases the end snapped off the ratchet in the shifter. Worth a look I guess
Posted : 04/05/2023 12:45 pm
Sounds like it’s terminally dead in that case - the ok just chuck it out when the new one comes. I’ve got another bike with sram GX eagle on it so will use that if I want to mtb this weekend!
I can’t bring myself to do another ride with my Transition Sentinel as a singlespeed just in 6th gear. 155mm of coil spring rear suspension isn’t conducive to efficient standing up pedalling 🤣
Posted : 04/05/2023 12:47 pm
Had the same with a xtr and it's replacement xt shifter both warrantied by shimano. Lost faith in shimano and now using a sram gx shifter with xt mech.
Posted : 04/05/2023 12:49 pm
I did toy with a GX shifter instead actually - but then I found the bargain slx so thought I’d try that. If that fails then sram will be tried instead.
I’d go full sram GX but Shimano 12 speed cassettes have better ratios towards the low end.
Posted : 04/05/2023 12:55 pm
Interesting, fwiw I've only ever broken SRAM shifters in the past, never broke an XT or XTR, even if I did I'd still stick with Shimano.
Posted : 04/05/2023 7:45 pm
sillyoldman reacted
Thread revival....
Does anyone know if you can get replacement springs to fix this issue? And if so, what us the part number?
TIA
Posted : 20/03/2026 8:12 pm
My XT shifter did this on a bikepacking trip to Cape Wrath. I was just by Loch Shin, which if you look on a map is just next to... nothing. Cool.
Anyway, all the research I did at the time pointed to a repair being unfeasible vs the cost of an SLX shifter. Apparently they have different guts in them and are not prone to this mode of failure.
(Oh, and I managed to bump into a worker at the Hydro scheme at loch shin who took pity on me grinding my way along the road to Lairg in my hardest gear. He was on hos way to Inverness to meet his sister and gave me a lift right to my door. What a hero)
Posted : 20/03/2026 9:42 pm
Yeah, it's definitely looking like new shifter time. Though I am tempted to just pop it open and see if the spring is intact enough that I can measure it and get one from a spring supplier. I hate throwing stuff away. Not sure if its cos I'm old fashioned, or it's becasue of my engineering/toolmaking background. TBF, if it's not insanely small I could just make another spring....Goes off to spend more time than it's worth source wire and make a small jig to wind another spring....
Posted : 22/03/2026 9:10 pm
I just chucked mine out. The slx had a lighter action but at some point I decided I’d pick up another XT one as it just felt nicer. Not had any issues with the replacement since.
Posted : 23/03/2026 6:52 pm
