XT 11 Speed shiftin...
[Closed] XT 11 Speed shifting issue
Wonder if anyone can help me here! Am running a M8000 XT 11 speed rear mech but whenever I engaged the clutch, it will not hop up onto the 42 tooth cog. Shifts absolutely fine without the clutch engaged.
So what am I doing wrong or do I need to adjust!? Thanks!
Posted : 30/09/2019 1:27 pm
B screw if it's too close?
Posted : 30/09/2019 1:34 pm
but would the b screw only prevent it shifting when the clutch is engaged?
Posted : 30/09/2019 1:36 pm
Too short a chain?
I run the same mech , not had this problem but in addition to the above replies you could also check the clutch friction. You need a torque wrench a T30 bit (I think)
The process is covered in this
   Page 20-21 as is all the other setup stuff..
Hope that helps
Posted : 30/09/2019 2:22 pm
My 11 speed acts the eejit when the B limit isn’t spot on so that would be my first port of call.
Posted : 30/09/2019 2:51 pm
