Am Looking at building an XC bike so best start with the frame. Preferrably Aluminiuym because I'm a weight weenie. Looking to spendabout £500 max.
Any idea's or recommendations let me know.
So far my favourite is the Yeti Arc
On-one scandal and use the money saved to buy better components elsewhere?
The carbon version might be good option too.
I used to have a kinesis maxlight 2. If the current model is as good that's worth a look.
XC play or XC race? if your talking weight suggests the later?
might be worth looking at Kinesis.
I so love my Rock Lobster tig team sl, frame is 3.25lbs.
Anyway, my rigid version is just under 20lbs, or I can quickly stick some fox forks on at 21/22lbs.
[IMG]
[/IMG]
[IMG]
[/IMG]
I was originally wanting the scandal, but the one I wanted (16" slot dropout) never came up on classifieds/ebay, I kind of bought the RL by default and as is, I don't see me parting with it for a few years. Also the On One carbon whippet might be worth looking at (shame about the decals), also as jonb, Kinesis do a real nice looking frame Maxlight.
Have a frame for sale that might fit your needs/price bracket. Drop me an email(in profile) and can send through some pics.
Whyte 19? You dont find many owners looking for another xc bike (inc me!). Actually to call it an xc bike is a bit limiting - you can tailor the geom / wheelbase a bit with the adjustable dropouts to favour short (race) to longer / slacker( &bigger rear tyres). My med frame weights 1.51 kg (3.3lbs) inc hs races and hangers.
btw - I'm not selling mine!
+1 for Kinesis. Love my xcpro2, and good value frames. XCpro3 out now.
I'd go with a Scandal personally, don't write it off just because it's inexpensive.
On one whippet or scandel 😀
I have a hardly used on-one scandal 18" frame for sale if you want.
Edinburgh based if you fancy coming round and having a look.
The frame weighs about 1.5kg and I built it up with average kit (lx) and it weighed approx 23.5lbs.
Hi Ian if you have any images of the frame you could email me,
Lewismorgan10@gmail.com
would be great. I'm from Lincolnshire so a bit of a trek! Off Mountain Biking in aviemore soon so could always have the possibility of dropping in. Anyway If you could send us some images would be great!
eBay carbon special, or Whippet for my money.
Isn't the Yeti ARC £700 now?
Yeti Arc is slightly pricey,
Would risk it from JensonUsa at £500 delivered, risk of tax i know but,
i live life on the edge!
Anthem X 2nd hand
Have only had two rides on mine so far but its pure class!
After a hardtail preferrably 🙂
On One Whippet is quite taking my fancy currently!
Yeti sure make a pretty bike, though i suppose turquoise and loopy chain/seat stays are a bit marmite.
Kinesis great value for money.
I've built up a couple of scandals for mates, and despite the on-one bashing encountered here, they are indeed silly light (weighed before built, 15-1600g depending on size and whether its slotty or normal dropouts) and I found them pretty well finished in terms of welds, tube shapes and anodising. Certainly on a par with kinesis if not quite as spangly as a boutique brand. BTW geometry/handling of scandal is the same as an inbred if you wanted to have a go on one, they are just lighter.
The Yeti looks and aesthetics are probably winning me over more than the actually frame and its geometry!
My worry with On One is the quality of the frames, Has anyone had any reliablity issues or anything with them? Although you seem relatively happy with them.
The Carbon 456 looks like a great all round frame!
The Whippet is the race frame, if you want light why look at the 456?
The whippet looks a bit more pure XC limited to only 100mm travel forks.
The fact that the 456 offers a bit more versatility on the riding and is lightly to take a few more hits draws me towards it!
I never had a problem with my steel inbred even handled small drops with no problem and loved the geometry for xc. Currently got a steel 456 it's not light but fun.
I'm just stuck between the 456 carbon and the whippet really.
Do you think i could push 120mm travel out of the whippet frame?
or will it start to struggle!
Does say 120 [url= http://www.on-one.co.uk/i/q/FROOCWH/on-one-carbon-xc-whippet-frame ]MAX[/url]
Same geo as the Inbred so it'll be good with 120 (if you like that sort of thing). I've been going back and forth on buying a Whippet to replace my Inbred the last few months. The BB kind of puts me off though (and I haven't quite justified the idea of changing yet either).
i can feel my wallet opening this morning!
can you get an adapter so that these BB92 push fit bearings will work with my external Diabolus BB :D?
nice scandal! just about to order myself a nice new C456 and can't wait fo her to arrive!! 😀
Just a thought, don't assume more is always better. The trend may be to run longer forks but you will find times when a little less travel works better. It does depend on how and where you ride.
Have just been looking at forks actually, got some Argyle 409's on my 4X bike only 100mm but ride as smooth as a babys bum, and spin beautifully on my CK Rockshox have really impressed me !
http://www.on-one.co.uk/i/q/FORSRERL/rockshox-reba-rl-dual-air-100mm-fork-with-poplock--26-inch
that doesn't seem a bad price either!
if you're going for 100mm forks then I'd get the whippet.
Think i'm decided on the whippet now,more of a race tweaked XC frame
Just slightly put off by its "weird" BB why not just use normal external cups?
Bb92 should be a better system, better support for the bearings.
hmmm im a big external fan
do they work witha standard front derailleur?
It says High Direct Mount
is this just implying top swing?
Be aware that the whippet is really designed for 2 x 10 set ups and not all all triple cranks will give adequate mud clearance.A few people have already damaged the frames running triples. The On One web site tells you which triples will work with it. It's top of my list to buy to transfer all the parts from my Boardman onto. That will involve going to 1 x 9 and taking an angle grinder to my chainset though!
stuck in two worlds between 456 and the whippet
Isn't there a slight problem in that both the whippet and the scandal out of stock?
YOU'LL NOT GO WRONG WITH A LOBSTER (VERY LIGHT TOO)
whippet is back on the 24th and 456 is in stock.
Ermm yeah but again Lobster====paying for name
second hand carbon trek 9.8 is tempting me!
after all this, I've purchased a gentlemans Trek 9.8 😀 😀
C456 might be in stock but the little bolts you need to fit the dropouts to the frame aren't 🙁 Going to be waiting a couple of weeks for mine apparently, it came with the bolts for a mk1 frame.
Even more racey than the Whippet you thought may be too racey! Good frame though!
