XC fork with full l...
[Closed] XC fork with full lockout?
Had Fox 32s and Rebas, both had a really stiff setting but still bounce when out of the saddle. Are there any that lock out completely?
Posted : 30/04/2018 10:18 pm
Dunno about forks but I have a DT Swiss XRC shock that does that. Might be worth investigating their forks.
Posted : 30/04/2018 10:23 pm
My epixons don't completely lock, but the amount of give in them is tiny when locked out, I can only move them a mm or two with my body weight when the bikes stationary. Guess it's a bit of a safety net if you inadvertently hit something hard.
There's certainly no 'bounce' I'm aware of when riding locked out.
Posted : 30/04/2018 10:27 pm
My Xfusions lock completely.
X-Fusion Sweep RL2
Posted : 01/05/2018 7:25 am
My Rebas don’t bounce at all when locked out unless they take a hit from the ground. You can set them up how stiff you want them to lock out.
Posted : 01/05/2018 7:49 am
My RS1's lock completely due to the adjustable flood gate.
I believe the DT Swiss XC forks my mate has do the same, this time via a cable lock out
Posted : 01/05/2018 7:51 am
I had my Rebas on the stiffest setting.  It didn't bouce as such when out of the saddle, but they did move a couple of cm.
If DT are still based on Pace then they probably do lock out, cos the Pace ones did.
Posted : 01/05/2018 2:11 pm
SIDs
Posted : 01/05/2018 2:14 pm
