x9 cranks - removab...
[Closed] x9 cranks - removable spider?
Looking at replacing my cranks to make it neater running 1x10. Looking at the 2x10 sram x9 cranks, is the spider removable on these?
Ta muchly
Posted : 07/11/2013 10:03 pm
Yes. I run mine with an MRP bling ring. Here's my Chameleon with X9 1x10. Three Torx bolts to remove the spider.
[URL= http://i978.photobucket.com/albums/ae265/mrgfisher/photo15_zpsb52f5c87.jp g" target="_blank">http://i978.photobucket.com/albums/ae265/mrgfisher/photo15_zpsb52f5c87.jp g"/> [/IMG][/URL]
Edit: Type 2 rear mech works well also.
Posted : 07/11/2013 10:16 pm
Yes. Remove the crank and you'll see two Torx screws behind the spider. If you unscrew these then the spider slides off.
Posted : 07/11/2013 10:21 pm
Mr Fisher is right - its 3 Torx screws!
Posted : 07/11/2013 10:27 pm
Merlin have X9 doubles for £75 at the moment including GXP BB. I believe X7 also have a removable spider, but double check first.
Posted : 07/11/2013 10:34 pm
Cheers all, it was the ones on Merlin I'd spotted. Intending running it with a thick / thin chainring, dropping the spider gives me more choices. £75 seems pretty good with bb as well.
Posted : 07/11/2013 10:43 pm
In my experience the bb's are junk. The one fitted to my Canyon lasted 6 months, the Hope that replaced it is still fine 2 years later.
Posted : 07/11/2013 10:50 pm
 mboy
If you're getting one of the cheap X9's off Merlin, and then gonna run it single ring, drop me an email, I'll almost certainly have the spider and 22/36 ring combo off you...
Posted : 07/11/2013 10:54 pm
I've just noticed the ones on Merlin are GXP, which is SRAM's version of HT2 isn't it (soo many BB "standards", does my head in). My bike's BB/PF30, would one of the adaptors on CRC ( http://www.chainreactioncycles.com/fsa-bb30-english-adaptor/rp-prod44067) do the job to convert?
mboy, I'll let you know as they'll be surplus to requirements!
Posted : 08/11/2013 10:50 am
mboy - email sent. I've bought the cranks, the FSA adaptor and Works Components narrow / wide chainring. Hope it all works! 😯
Posted : 08/11/2013 12:49 pm
mboy - tried emailing but got no reply. You intersted in the rings / spider fella?
Posted : 13/11/2013 1:07 pm
if Mboy is not and they are 22/36 then i would be....
Email in profile 🙂
Posted : 13/11/2013 1:36 pm
I think Mboy should be very interest.. I'll see if I can give him a prod.
PS: If he doesn't I'll give him a bloody good kicking, cause they would have fitted my chainset replacement plans a treat.
Posted : 13/11/2013 1:53 pm
 rj
I've just bought a set of X9s and was going to bodge them to run single ring, but this looks like a much better idea. If the OP disposes of his spider and rings, I have a set that I'm pretty sure are 36-22, unused that have suddenly become surplus to requirements.
Posted : 13/11/2013 9:28 pm
 rj
Oops, double post.
Posted : 13/11/2013 9:29 pm
RJ, YGM
Posted : 13/11/2013 10:06 pm
Cheers z1ppy. They're definitely surplus to requirements so would be good to get a few quid for them. Just waiting for the works components chainring so I can get it built up.
Posted : 14/11/2013 12:00 am
