X-Fusion Velvet 140...
[Closed] X-Fusion Velvet 140 forks
Anyone running X Fusion forks. Are they as good as the reviews say?
Posted : 21/04/2013 7:27 pm
I have a set of x fusion velvet forks set at 120mm and can say they are very good for the money . I have the basic lock out and rebound pair and havent had any problems whats so ever ! and they only cost £340 new so great value ! also they are 650b compatible which is good too if you wish to go down that route ?
Posted : 21/04/2013 7:33 pm
Yes.. They are ace.
Posted : 21/04/2013 7:39 pm
I think I have them on by Ibis, and to be honest I think they're mince. They got too much stick and don't really bounce much.
I'm not much of a mechanic though, so if you're into all that mechano stuff then I guess you could get them to work ok.
Posted : 21/04/2013 8:05 pm
Think they're great, need a bit of fiddling with air pressure, but at least as good as the revelations they replaced.
Bargain 8)
Posted : 21/04/2013 8:47 pm
I have a set of the DLO ones on my hardtail. They seem like a perfectly effective fork.
Posted : 21/04/2013 9:04 pm
I have a pair and they're just about bedded in after 3 rides (about 60 miles off road and 20 on). Need to set them up a bit better now they are, but they're very plush. As good as my old dual air Revelations that they replaced; smoother certainly. I'm not sure if they're as stiff as the 20mm axle Revs they replaced as I've gone for a lighter flexier wheel at the same time but they track well enough.
They currently have too little pressure in so are diving a bit on slow steep stuff.
Posted : 21/04/2013 9:13 pm
I have a set of 130mm's which are great. really good performance and good value compared to some others.
Posted : 21/04/2013 10:23 pm
Do they lock out at full travel or lock down at sagged position?
Posted : 21/04/2013 11:25 pm
Posted : 21/04/2013 11:49 pm
