X fusion forks.. Wh...
[Closed] X fusion forks.. Who knows?
 SOAP
Can I drill a hole in the rod to make them 130mm travel? Rather than 120 or 140mm
Posted : 23/02/2014 9:24 pm
Yep I did
Posted : 23/02/2014 9:26 pm
Or just set them at 140mm but add a 10mm all-travel spacer to sort it without having to drill anything
Posted : 23/02/2014 9:28 pm
 SOAP
I need to get my A2C down.. And 130mm is the limit.
Posted : 23/02/2014 9:30 pm
The spacer does exactly the same as drilling it, just doesn't need drilling. You'll still end up with shorter A to C
Posted : 23/02/2014 9:32 pm
 SOAP
Got a link matthew_h ?
Posted : 23/02/2014 9:34 pm
If you need a spacer try Jim at JTECH or upgrade
Posted : 23/02/2014 9:36 pm
Nope but we've done it in the shop loads. Leave the disc with the split pin where it would be for 140mm then add a 10mm spacer between it and the rest of the spring assembly. Has exactly the same effect as drilling and moving the disc down but means no drilling, keeping the fork intact and is entirely reversable.
Posted : 23/02/2014 9:37 pm
 SOAP
Ahh ok I got it now.. Bit like a fox volume reducer?
Ill give him a call tomorrow.
Posted : 23/02/2014 9:41 pm
It's not the best photo but this kinda shows what I mean:
Posted : 23/02/2014 9:45 pm
 Alex
J-Tech did mine when I bought a new pair of Trace's.
Posted : 23/02/2014 10:04 pm
