X-Fusion Forks DLA ...
[Closed] X-Fusion Forks DLA Feature
Am I missing something, or is DLA!=On the fly adjust?
I've been reading the Freeborn Cycles page and though they mention the travel can be stepped down the features don't seem to mention an on the fly adjustment like TALAS etc. Am I looking at internally stepped down adjustment for these?
Posted : 27/08/2013 4:08 pm
They utilise a dial on the top of one of the stanchions, so it is on the fly, much like TALAS.
Hope that helps.
Posted : 27/08/2013 4:13 pm
 Kuco
You just turn the knob on the top of the left stanchion and on my slants and it goes from 160mm to 130mm.
Posted : 27/08/2013 4:14 pm
Cheers guys.
Posted : 27/08/2013 5:09 pm
On the Vengeance you have to turn the knob and then pump down (170-140mm)
They can also be stepped down internally
Posted : 27/08/2013 5:48 pm
There's a factory-fit option to internally shim certain forks to 650b (thus making the trail come alive...probably), but otherwise all adjustments are via the excellent controls on the forks
Posted : 27/08/2013 6:57 pm
anyone know if it's possible/how easy it is to change the Vengeance to 650b? Their website seems to imply that it can be a 650b fork, but there's no "how-to" guide that I can see.
Posted : 27/08/2013 7:02 pm
Erm - it just takes a 650b wheel rondo101. What do you imagine you could alter between the arch and axle? ๐Ÿ˜‰
Posted : 27/08/2013 7:21 pm
Yeah, on the Freeborn site it says a few of them are 650B compatible out of the box. Like the guy above said, not sure what you could do to make it 650B compatible apart from cut a section out of the brace!
I think they were mostly the longer travel ones.
Posted : 27/08/2013 8:18 pm
The distributer will probably be able to change the fork to 650b. Its a spacer thing, Drop them a line.
Posted : 27/08/2013 8:21 pm
It's got nothing to do with spacers - the area where the wheel attaches to the fork and the clearance to the tyre is a solid piece of metal, ergo a fixed length. The 2013 Vengeance accepts a slightly bigger wheel than a 26" without the tyre fouling the arch - simples!
Posted : 27/08/2013 8:28 pm
You must be right. X Fusion clearly have no idea what they're talking about. You should email them and put them straight...
[url= http://www.xfusionshox.com/product/forks/velvet/rl2r.html ]X Fusion RL2R[/url]
๐Ÿ™„
Posted : 27/08/2013 8:35 pm
Velvet, Slant, Vengeance can be run with a 650b wheel. There's enough room under the arch, but they need an internal spacer fitting so that they bottom out earlier - to avoid the tyre hitting the crown under full compression.
Posted : 27/08/2013 8:39 pm
oops, beaten to it by mangatank.
Thanks Mangatank & Simon.
Any ideas what increments the travel on the Vengeance can be reduced by (internally, rather than the DLA version)?
Posted : 27/08/2013 8:52 pm
My apologies too.
I guess this means you'll lose some of the travel so a 170mm fork on a 26" wheel becomes 160mm or something on a 650B wheel?
Posted : 27/08/2013 8:53 pm
So rondo asks about the Vengeance, I reply with a response relating to the Vengeance and you link to the Velvet - ok.
I get where you are coming from, however, the Vengeance is 650b compatible, without any messing about
[url= http://www.xfusionshox.com/product/forks/vengeance-series/hlr-dla.html#specifications ]Vengeance[/url]
Posted : 27/08/2013 8:58 pm
Internally adjustable to 160/130/100mm from 170mm
Posted : 27/08/2013 9:03 pm
I'd have to check on that - I'm not sure whether Vengeance is the same situation, I'd imagine so.
The travel spacers (on none-DLA air forks) is either a ladder/pin system, which has differing options on differing models, or we've fitted 10/20mm spacers. Pretty much anything, in 10mm steps.
Posted : 27/08/2013 9:05 pm
Me:
There's a factory-fit option to internally shim [i]certain[/i] forks to 650b
You:
you link to the Velvet.
Happily.
Posted : 27/08/2013 10:53 pm
