Hydraulic brake cab...
[Closed] Hydraulic brake cable grommet/clamp doodah's
Hello all,
I've just about finished my build, but i'm short on two small clamps that hold the hydraulic cable to the underside of the top tube.
The frame is a kona kula supreme and there are three fixing points running along the underside of the top tube. The middle fixing allows a tie-wrap to be threaded through (which is done), but the left and right hand ones are open and it looks like something clips over the cable into the fixings. The fixings don't have any holes or lugs as such so i guess it's some sort of 3/4 barrell that goes over the cable and into the fixing groove.
I'll try and do piccies later.
cheers all.
Posted : 06/08/2009 3:06 pm
