[Closed] WTB Nano 40 but a bit narrower
I need something a tiny bit narrower than a WTB Nano 40, a WTB Nano 38 would be the best choice, but they don't appear to make one.
So what are my options? I don't run tubeless and am happy to run the standard quality rubber, so value is certainly a priority.
Black sidewalls please
My nano 42s measure 41mm. The 40s I had before were 38mm with tubes and grew a bit closer to 40 tubeless. They do come up a tiny bit small in my experience.
Have you tried the 40s? Also what bike (and rim width). My croix spec says max tyre width 35mm but plenty of clearance with 42s on (I guess I am just saying don't go by frame spec)
Don't they do nano in 32/35mm?
Yeah they do
OP have a look at this thread... Lots of other options
http://singletrackworld.com/forum/topic/what-35c-cross-gravel-tyres-are-you-using
Cheers all. Its a kinesis pro 6 v2 with Kinesis wheels. I've been running the nano 40 and it needs replacing, whilst it's been fine there a few rub marks in the inside of the chainstay and I was hoping to replace with something similar, just a tiny bit narrower.
I'll check the other thread. Thanks
Hi
I have been running Nano 40c front with a Riddler 37c rear seems to be a good setup but will possible changing both to a Riddler's
