Would you fix a shi...
[Closed] Would you fix a shimano Caliper or replace?
I’ve got a set of Deore brakes (about 2015 model) that I bought off a mate, he’s ridden them about twice, when I bought them I bled them as there was nothing going on with the front one, turns out it was completely empty.
I presumed he’d just had a go at bleeding them and royally ballsed it up. Bled it and it’s fine.
Next time I actually ride it the thing is squeeling like a stuck pig and I notice oil over the calliper and shiny wet pads. Great.
Cleaned it it up yesterday, checked the bleed nipple and hose union were all good and off I went. Seems to be leaking now from the bleed nipple - looks to be from the nipple itself rather than the threads.
now, I can buy a new bleed nipple for a fiver or for £25 I can buy a complete brake from CRC, replace the Caliper and sell the new lever on. In your experience is it worth trying to fix them or just replace?
Posted : 22/07/2018 2:59 pm
New one will come with pads.
ID keep the used one for spares, you will probably need them.
Posted : 22/07/2018 3:07 pm
If the sealing face on the nipple looks ok I'd be suprised if a new one sorted the problem. There could be damage in the calipre itself.
For £25 I'd be tempted to change the lot and save any bother.
Posted : 22/07/2018 3:09 pm
Pretty much as I thought, and good call on the pads. Ta
Posted : 22/07/2018 3:42 pm
