Would you believe i...
[Closed] Would you believe it, clothes pegs worked! Tubeless content
Tried for an hour to get a 29er rim and maxxis Crossmark 2 done tubeless. Tried with valve core out, tried a tube around, the outside etc, no good.
Got 11 pegs around the edge, ping! Straight up! Ha ha.
Posted : 30/06/2018 10:45 pm
So you're advocating pegging to anyone with an already slack rim?
Posted : 30/06/2018 10:56 pm
Errrrrm I dunno. I'm not down with the cool kids on these words. Maybe?
Posted : 30/06/2018 11:01 pm
Pushing down hard with your thumb into the rim over the valve can often make the difference for this sort of job too...
Posted : 30/06/2018 11:08 pm
I thought I was the only person to have used pegs. Glad it worked for someone else as well though.
They don't half ping off when the bead seals though.
Posted : 01/07/2018 12:01 am
I’m struggling to picture this.. where do you fit the pegs? Is it around the rim either side , with the tyre sandwich is the well of the rim? Interested!
That said, since running Hope and Maxxis I’ve had zero issues. They go up in 5 mins each, if that.
Posted : 01/07/2018 12:23 am
Posted : 01/07/2018 12:37 am
Pegs at the start of tread and halfway down sidewall, it's like you're pulling the sidewall closer to the bead. I was sceptical before hand but had run out of ideas with his rim and tyre combo
Posted : 01/07/2018 7:18 am
@bsims Ta!  This does actually work btw... 😳
The pegs, though. I’m struggling with this still. So, the pegs are down the side of the tyre?  Guessing this is one of the super lightweight tyres that really just wants to sit flat and not be tyre shaped, then?
Posted : 01/07/2018 8:44 am
If you have a tyre where the bead is sitting in the well of the rum rather than the bead socket and all the air escapes before pushing the tyre bead outwards, you can try this.
Pegs go on the bottom of the tread/top of the sidewall and effectively flatten the top of the tread and pull the bead closer to the bead socket allowing air to get behind the bead and push it into the rim shoulder.
Posted : 01/07/2018 9:14 am
Crossmark 2. So xc biased but not super lightweight etc. I should have taken a pic really.
It's stayed up solidly overnight so all good.
Posted : 01/07/2018 9:15 am
It’s stayed up solidly overnight so all good.
Oh to be a teenager again
Posted : 01/07/2018 9:24 am
Zip ties joined together to go around the whole wheel does similar.
Posted : 01/07/2018 10:10 am
Thanks vincienup. I will remember that advice.......when I have difficulty with a tyre. It would not have even registered in the teenage lobe of my brain if teethgrinder had not said
So you’re advocating pegging to anyone with an already slack rim?
Looks like it stimulated the teenage lobe in rOKeTdOg as well!
Posted : 01/07/2018 10:23 am
