Workshop help neede...
[Closed] Workshop help needed. Two things....
first: can i swap the cages over between two rear mechs? i want the short cage (old style) XT cage on an (old style) LX rapid rise mech.
how?
second: how do i take the wobble out of an XT rear hub? what do i need to tighten and where? i'm willing to stick some araldite on there to stop it working loose again.
cheers
J
p.s. can anyone recommend a decent, solid rear hub that won't work loose like the XT. "XXXCountry" riding.
Posted : 05/11/2009 5:13 pm
Hope hubs fo shiz.
Swapping mech cages... don't think so. Aren't they riveted in or something?
Posted : 05/11/2009 5:14 pm
"a decent, solid rear hub that won't work loose like the XT"
Well, XT won't work loose given a little preventative maintenance...
Posted : 05/11/2009 5:21 pm
Hubs- tighten your XT up properly (tighten the locknut against the cone properly so that neither can work loose). Other than XTR there aren't many better hubs.
Cages- can't be swapped.
Posted : 05/11/2009 5:22 pm
CAGES CAN'T BE SWAPPED!!!! bugger.
you sure, though? want the shorter one on....
Posted : 05/11/2009 5:28 pm
Sram ones can be swapped, which is why they fall apart.
Posted : 05/11/2009 5:32 pm
ok.
so how do i adjust the hub? i've had it done once at the bike shop but didn't pay attention...
Posted : 05/11/2009 5:41 pm
You need a set of quality spanners to adjust the hub.
There's no point trying if you don't have them.
It's pretty simple if you are in anyway mechanically minded - just a cone+locknut on each side (+ a few spacers).
The trick is to get the cone at the right tightness against the bearings (ie no play but smooth) and VERY tight against the lock nut - this is where good spanners come into it (if the lock nuts aren't really tight, they will come loose again).
Posted : 05/11/2009 5:57 pm
have a look on the parktool website - lots of top workshop tips on there.
