Works components he...
[Closed] Works components headset - easiest way to get back to zero?
I've got an On-One Codeine which I bought second hand from here. It came with a Works Component 2 degree headset.
I think this just makes it too slack and floppy for my liking - trying to ride it through twisty turny Thetford singletrack gives me motion sickness after a while. It's probably not helped by the forks which have a 46mm offset.
(OK, a 140mm travel 29er is never going to be ideal in such conditions but even so).
Do I just remove the headset and put in a regular one, or is there some ingenious hack I can do that means I don't have to knock-out and replace the top and bottom races?
Thanks
Posted : 19/02/2018 9:54 am
You could invert the cups which would make it 2˚ quicker steering than stock, but basically you just need to fit a standard headset. I found the sealing on the WC headsets was appalling anyway and things just tended to seize up.
Posted : 19/02/2018 9:59 am
I've found a really great way to do this - I'm going to take it to my LBS who will fit a Hope Headset for me. This means that I don't have to do the whole whacking with a great big hammer thing, which I hate.
Posted : 19/02/2018 11:53 am
More importantly....... motion sickness?
Posted : 19/02/2018 11:55 am
