Will this permutati...
[Closed] Will this permutation work?
Will a normal front mech swap between a 24 36 44 permuation of ramped front rings comfortably? I normally use 24 34 44, Just wondered if the assembled had a view on this. Thanks in advance.
Posted : 03/08/2009 10:11 pm
Should do - I run 22/36 on the tandem and put a 44 on it as well for touring. You only get two higher gears - one of which is only a tiny bit higher tho.
Posted : 03/08/2009 10:25 pm
You might have to move the mech up a bit so the gate for the middle ring lines up correct.. and I think a conventional mech might work better than a low band coz of the way it moves up as it moves out, as opposed to moving over the top of an arc.
Posted : 03/08/2009 10:26 pm
Should work no problem, the maximum difference you can normally run between two chainrings is 16T.
Posted : 03/08/2009 10:31 pm
