Will offset bushing...
[Closed] Will offset bushings reduce stand-over height Orange Five?
Hi chaps,
Currently have an 18" Orange Five, it's a little too big. Would adding Offset bushings to the rear shock lower the standover height. Anyone have any experience with this?
Looking at purchasing a set from http://www.offsetbushings.com/
Any help would be much appreciated.
Posted : 16/04/2013 2:35 pm
It's unlikely to change it by enough to really make a difference.
Posted : 16/04/2013 2:38 pm
how much do you need?
If you sac is catching then probably not enough
In theory, yes, as they basically lift the swingarm up a bit. So head and seat angles are reduced, as are BB and standover height. But not by much.
Posted : 16/04/2013 2:39 pm
It can lower the BB and alter the angle of the dangle, it may be half an inch lower at most.
Posted : 16/04/2013 2:40 pm
If its too big offset bushes won't help. Yes it'll be lower but everything else will be exactly the same
Posted : 16/04/2013 2:42 pm
Ideally I'd want to reduce by an inch but at the cost of a new frame I'd rather try offset bushings first.
Sac doesn't catch that often [touch wood]
Posted : 16/04/2013 2:45 pm
PMSL
Posted : 16/04/2013 2:46 pm
Maybe you'd be better borrowing a pair of 5 tens to see if increasing your height helps and/or maybe lower profile tyres,might just do the trick.The next size down Orange frames is a 17 inch with only 20mm more standover.My 5:tens make me an inch taller!
Mind you if the frame is too tall then you really need a frame with a lower standover height
[img] https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcR3_91j0Ffmob4DGeJQtZsrSkAzNaf4TCqEN6iw1QQ51ZWw3k8kTw [/img]
Posted : 16/04/2013 2:56 pm
Offset bushings are for slackening everything out, not for making wrong sized frames fit people. Do you want to slacken everything out as well?
Posted : 16/04/2013 3:04 pm
Oh, and plus I find I hit my cranks on stuff on my Five more than any other bike I've ever owned. Lowering the BB height would be the last thing I'd want!
Posted : 16/04/2013 3:05 pm
Offset bushings are generally 2mm or 3mm. A pair of 3mm bushes leads to a reduction in effective eye to eye of 6mm, so at rest it's equal to the current shock compressed by 6mm.
Orange 5 has 140mm from a 51mm stroke shock is approx 2.75:1 - so a 6mm shock drop would move the wheel up by about 16mm.
That's at the rear wheel - the drop at the top tube would be about half that so nowhere near the inch you desire.
Plus above, slacker, lower, possible clearance problems...
Posted : 16/04/2013 3:15 pm
Thanks for all the comments, I think a new frame would be the most effective option.
What to buy, smaller Five or something else. SB-66 looks tempting ๐Ÿ™‚
Posted : 16/04/2013 3:40 pm
