Will it be ok?
[Closed] Will it be ok?
[#3884054]
Went out riding last night and just cleaned my bike this morning and noticed theres a thumb size slit in the sidewall on my rear tire, im running maxxis minions duel ply 2.35, its not really deep but u can see the fabric inside, is it worth getting a new tire or can i fix it or will it be ok? cheers!
Posted : 18/04/2012 11:12 am
 D0NK
can you see the innertube or has it just gone through the top rubber coating/first ply? If you can see the tube definitely replace.
Posted : 18/04/2012 11:18 am
That's the reason Super Glue was invented [probably]
Posted : 18/04/2012 11:20 am
superglue won't help on a sidewall.
You can patch/stitch it though.
Posted : 18/04/2012 11:27 am
erm dont think you can see the innertube i think its just slit the sidewall its self
Posted : 18/04/2012 11:43 am
 IA
Gaffer on the inside's seen me right before...*
*some sort of disclaimer here, might have your face off etc...
Posted : 18/04/2012 12:17 pm
If you do try to repair it use dental floss to stitch.
Posted : 18/04/2012 12:19 pm
gaffer tape on the inside sounds a good idea, ill give that a go, hopefully its not gone all the way through as i said it just seems like a small slit on the top layer because u can see all the stitching on the inside of the " duel ply " ill take it off and have a look cheers
Posted : 21/04/2012 7:34 pm
I had a similar issue. As a temporary repair I gaffer taped a bit of old toothpaste tube into the inside of the tyre just in case and then whilst the tyre was inflated I put araldite across the tear as some protection. Ran the tyre for another couple of thousand kms without an issue.
Posted : 21/04/2012 8:26 pm
repair with rubber vulcanising solution. Its for rubber! Strangley, it seems to work quite well.
Posted : 21/04/2012 8:50 pm
