Will I need a new c...
[Closed] Will I need a new chain tool going from 9 to 11 speed chains?
I have an oroginal Pedros chain tool that I have been using on 9 and 10 speed chains.. will I need a new one for 11 speed chains..
Thanks..
Posted : 17/07/2015 2:11 pm
Not if you use a quicklink to join it.
Posted : 17/07/2015 2:12 pm
OP. No, you'll be fine with the one you have.
Posted : 17/07/2015 2:20 pm
Thanks! Phew!
Posted : 17/07/2015 2:22 pm
[i]Not if you use a quicklink to join it.[/i]
Then you'll need a quicklink tool. Anyone who can join Sram 10/11spd quicklinks by hand has my utmost respect.
On a similar subject, I still use an old 8 speed chain whip when removing cassettes. (Just to put the OP's mind at rest)
Posted : 17/07/2015 2:36 pm
Joining a Sram Powerlock is easy. Pedal the link to the top, push down on the pedal and the tension will lock it together.
Posted : 18/07/2015 12:03 am
