Will Campag xenon 1...
[Closed] Will Campag xenon 10s shifters work with shimano rear mechs ?
Just pricing up shifters for a budget build and came across the campag levers , is the pull ratio the same as shimano or not and anyone tried them?
Posted : 26/12/2015 11:43 am
 jonk
Interesting article [url= http://www.cxmagazine.com/shimano-campagnolo-ergopower-compatibility ]here[/url] about this
Posted : 26/12/2015 11:54 am
Cheers for that, interesting indeed
Posted : 26/12/2015 12:05 pm
There's a page on the CTC site re shimergo which should tell you but I find it difficult to understand.
I run 9s ergos with a shimano mech and its just about OK on 8s. So 10 might work OK on 9.
If they have plastic levers them AVOID, they are terrible.
Posted : 26/12/2015 12:07 pm
You could use a Jtek shiftmate...
http://www.jtekengineering.com/resources/shiftmate-compatibility/
A number 3 will make 10spd campag shifters work with a shimano mech & 10spd cassette
Posted : 26/12/2015 12:35 pm
Shiftmate costs £30, you can get a xenon rear mech for about £25.
Posted : 26/12/2015 12:46 pm
+1 for Jtek shiftmate
I ran 11 speed Campy Chorus shifters with a 9 speed xtr rear mech and it worked well enough, however the shifting was a bit cluncky onto the second largest cassette cog.
I bought a Jtek shitmate and the shifting is perfect across the whole block now - would recommend them.
Posted : 26/12/2015 12:59 pm
10spd Ergos will work perfectly across an 8spd Shimano cassette, or 9spd with the hubbub clamp method in that CTC article.
Posted : 26/12/2015 6:50 pm
Shimergo works perfectly - I did it for 5 years. 10s Campag shifter with 9s shimano mech, 9s shimano cassette. Note the cable needs to be fitted to the rear mech in a special way.
Alternatively 10s Campag ergo works perfectly with a shimano or sram 10s cassette and SRAM 10 speed rear mech which allows use of a clutch mech if you're using it for cx as I am.
Posted : 26/12/2015 8:32 pm
