will a Cannondale h...
[Closed] will a Cannondale headshok fit a 44mm headtube?
Hello, i have a new frame with a 44mm headtube and i was wondering if a cannondale headshok would fit that?
cheers
Posted : 11/07/2012 3:04 pm
[s]I can't say for sure but I think yes[/s] actually reconsidering this I'd suggest no, as a lefty (and so I assume headshok) has a diameter of 1.56", not 1.5 as per the 44mm headsets/cheap forks you can get.
Edit: If you want to get pedantic, it may fit "inside" the headtube but you won't get a headet that'll fit both together.
Same issue when the 1.5 standard came out, ppl assumed lefty/1.5 stem would fit both... nope
Posted : 11/07/2012 3:58 pm
cheers for that. Done a wee bit of searching around the web and you can buy an 1 1/8th convertor to run a Lefty so that might be an option for me ๐Ÿ˜€
Posted : 12/07/2012 9:24 am
๐Ÿ™‚
Posted : 12/07/2012 9:27 am
haggis1978 - Member
You can, and they're ace...
Posted : 12/07/2012 9:30 am
