Will a 3X10 front m...
[Closed] Will a 3X10 front mech work with a 2X10 set-up?
I'm assuming it won't (due to triple mech angle/'throw') but just want to be certain!
This would be on one bike with a direct mount front mech and another bike with a standard band-type front mech. Chain rings would be 28/40t, mounted on inner and middle ring tabs.
Posted : 11/10/2012 11:54 am
yep - works fine, just set the limit screw so it can't change into 3rd ring.
Posted : 11/10/2012 12:03 pm
No way send it to me and I can do the mods to make it 2 speed just PayPal gift 30 quid plus postage......
Posted : 11/10/2012 12:06 pm
For £30 I'll just buy a new front mech!
Posted : 11/10/2012 12:12 pm
If you're using a triple crank set and removing one ring then yes it'll work. As footflaps says, just set the high limit screw to stop it shifting into the 3rd position.
Posted : 11/10/2012 12:15 pm
Yes it will work BUT, you might not be able to set it up to the correct hight, outter plate 1-2mm above the biggest ring, as the inner plate can be deaper (longer) on a 3spd than a 2spd front mech, and the inner mech plate can rub on the inner ring.
The mech will still work at a high height, but you might find it doesn't shift as crisply as before and chain might be more prone to comming off.
but saying that, mine worked OK when I did mine.
Posted : 11/10/2012 12:52 pm
Although i was using a direct mount mech, lowered as much as possible, i lost the chain on every DH and it drove me insane
Not sure if you'll get the same on a band mounted mech but would be interested in your feedback
Posted : 11/10/2012 1:13 pm
