Wider Bars: What di...
[Closed] Wider Bars: What difference does it make to bike geometry?
I am in the process of replacing my narrow flat-bars (600mm) with low riser bars (680mm), which got me thinking what difference will this make to my bike's geometry?
My guess is I will be more stretched out so am worried about my lower back, or does everyone compensate with shorter stem?
Anyone got any experience of this or advice beyond mtfu?
Posted : 23/06/2013 6:52 pm
They slow the steering at your hands and give you more leverage, which means you don't need as much self-centring from the stem length, so can go for a shorter stem which conveniently sorts out the reach issue.
Posted : 23/06/2013 7:04 pm
They don't alter the bike geometry, they alter your geometry
Posted : 23/06/2013 7:07 pm
cheers chiefgrooveguru.
makes me think is there some kind of rule of thumb, say 80mm extra on the bars would equate to 10-20mm shorter stem?
Posted : 23/06/2013 7:09 pm
your right, i thought that just after pressing send; should've been clearer in specifying rider geometry on the bike?
Posted : 23/06/2013 7:10 pm
Actually I think they do alter the geometry, as the handling of the bike is felt through its interactions with the contact points.
Posted : 23/06/2013 7:29 pm
Every time I've widened bars, it has improved the handling of the bike. I'm quite broad shouldered, so a 680 bar still felt a bit narrow. I'm now running 747mm bars, and these are perfect. If you've been riding long enough, you should have some feel for where your hands are, so I don't find them awkward in trees.
It also opens your stance out a bit, and makes you 'feel' attacking IMO. Apart from this, it lengthens the reach a little bit, but not noticeably.
I've found that since running the wider bars, I am pulling the bike up harder out of corners and generally just chucking it around a bit more. It's probably more of an attitude shift than a geometry change.
If you do end up with bars that are too wide, you can always break out the hacksaw.
Posted : 23/06/2013 8:55 pm
thanks Dannyh, will report back on handling impact but anything that gives greater confidence to throw the bike around has to be a good thing!
Posted : 23/06/2013 9:47 pm
no rule that I know of but I would think 80mm wider would be comfy with 20mm less stem
"it all depends"
go wide, proper wide, cut down if not happy but you probably won't.
Posted : 23/06/2013 9:51 pm
 JoeG
680 mm is not wide, at least not by today's standards.
About 5 years ago, I ordered a 27.5 inch (700 mm) wide bar through a LBS. When it arrived and I went to pick it up, they were darn near pissing themselves laughing at how ridiculously wide it was. Oh how things change...
Now I'm at 760 mm with a 60 mm stem, and really like it. I was using 670 mm bars and a 90 mm stem.
Posted : 24/06/2013 3:39 am
Simple advice, only change 1 thing at once.
Fit new bars.
Ride bike.
Evaluate where you are and decide if you want to change anything, your current set up might not be optimal.
If you do want to play with stems then use old ones/borrow some. It would be good if LBS's had a loner stem box for trying stuff out with.
Posted : 24/06/2013 4:08 am
Mike, whilst the sentiment is good I would be worried in this case that if someone had a 90mm stem and 680 bars and went to 740mm bars without changing the stem for something shorter, then they would likely conclude that wide bars are rubbish.
Posted : 24/06/2013 5:13 am
toys19 - Member
You could but the key part was to evaluate, I went from 685 to 760 on the same stem, the difference was great - 70mm stem on that bike for reach reasons, any shorter and my knees used to take out the shifters ๐Ÿ™‚
Posted : 24/06/2013 5:23 am
 hora
How broad is broad? Is there...an equation? ๐Ÿ™‚
Posted : 24/06/2013 5:56 am
Broadness is proportional to closeness to norfolk
Posted : 24/06/2013 6:31 am
I always go with
Different landmass + different language = 'broad
Posted : 24/06/2013 6:32 am
[url= http://www.pinkbike.com/video/192057/ ]explanation here[/url]
Posted : 24/06/2013 8:30 am
Thanks for all the advice. Think I might stick with change one thing for now, ride it then see if stem needs changing bearing in mind people's thoughts. cheers!
Posted : 24/06/2013 9:24 am
