Wider bar similar ...
[Closed] Wider bar similar effect as longer stem?
 Earl
Got a 80mm stem with 620mm wide bars on at the moment and it's a bit cramped (tbh bike is probably a bit small). Would getting wider bars be similar to getting a longer stem?
Ta
Posted : 20/03/2011 9:53 pm
If you think the bike is too small anyway, wider bars will increase the chances of your knees hitting your hands on tight turns.
A longer stem would be a better way to compensate for too short a top tube.
Posted : 20/03/2011 10:05 pm
Both cured it for me, get wider bars if you think you're grips aren't wider than your shoulders.
Posted : 20/03/2011 11:57 pm
