Whyte dropper post ...
[Closed] Whyte dropper post movement up and down.
Got a Whyte branded dropper on my E150 and on the last ride it's developed a fair bit of play up and down and is acting more like a suspension seat post now.
I've took it out the frame and disconnected the cable to rule that out and it's still doing it.
I have a feeling it may be a brand x dropper that is rebranded as Whyte.
Anyone ever come across this before ?
Post is 3 rides old and less than 50 miles.
Posted : 13/12/2020 12:41 pm
Pretty common on the Facebook group. Standard answer seems to be to check the pressure and pump it up
Posted : 13/12/2020 4:32 pm
Pump it up?
I thought it was a sealed cartridge?
Got a link to the Facebook page please
Posted : 13/12/2020 4:50 pm
Due to the wonderful way Facebook works, no I can’t. However, it’s called Whyte Bikes - Owners so pretty easy to find.
iirc it’s basically a Brand X post. No bad thing. I don’t own one though so I could always be talking shite
Posted : 13/12/2020 7:01 pm
Sounds like too much cable tension. Try slackening it off with the lever's barrel adjuster.
Posted : 13/12/2020 7:18 pm
Mine been fine, they have good support just throw it back at them.
Not much you can do if it’s the same with the cable disconnected.
Posted : 13/12/2020 7:33 pm
Is it the adjustable travel dropper, or the original drop it II one? Both are sealed cartridge AFAIK.
Mine has the adjustable which looks identical to this TranzX.
https://bikerumor.com/2020/03/04/salsa-partners-with-tranzx-to-create-tool-free-adjustable-travel-dropper-post/
If 3 rides old I'm sure Whyte would just swap it out.
Posted : 13/12/2020 7:41 pm
Jamze it is indeed that one. I will speak to the shop tomorrow.
Posted : 13/12/2020 8:29 pm
Have you checked the travel-adjustment bushing thingy is located properly? Just unscrew the top.
Posted : 14/12/2020 9:30 am
Yep did that too mate. No joy.
Need to ship back to the shop I got it from.
Posted : 14/12/2020 11:54 am
